Old 11-05-2008, 04:42 PM
jeffd jeffd is offline
I saw a post long ago on thumpertalk on the tubeliss setup. The person weighed it and there is no actual advantage in weight relative to a tube.
So only real advantage is that you can run lower pressure without risking a pinch flat?
Old 11-07-2008, 05:24 AM
iancp5's Avatar
iancp5 iancp5 is offline
I'll stick with Mousses. They seem reliable and I don't seem to be lacking on grip compared to others racing near me on the tricky bits.
Old 11-07-2008, 08:28 AM
gasser's Avatar
gasser gasser is offline
Question
The advantage of the tubeless system (if they are durable) would be the cost savings long term. I am not a racer so the I don't mind carrying a tubeless tire repair kit when I ride. As far as the weight goes was the tubeless system compared to a heavy duty tube and a rim lock? Another factor is the weight of the tubeless system is carried closer to the center of the wheel - would that make a noticeable difference in handling or acceleration?
Old 04-12-2010, 06:05 PM
HydroDog's Avatar
HydroDog HydroDog is offline
Well I decided to bite the bullet and buy a set of tire balls to run in my trials tire.
Not being a big fan of changing tires anyhow the installation of the tire on the rim was a little harder than shown in the video but only a couple of F- bombs could have been heard by the neighbors at 11 at night.
I usually run 8 to 10 psi in my trials tires but after playing around stacking the balls in the tire and squeezing it like it would be on the rim I lowered the air pressure to 1-1/2 to 2psi and stuffed 25 of them black eggs in there. The pressure might sound a little low but if you have one in your hand and squeeze it the pressure go's up pretty quick.
I rode 45 mi. the next day and the rear suspension response is much better then using the ultra heavy duty tubes from the reduced unsprung weight. The tire seams a little firmer than before but some of that could be from switching from the IRC tire to a Dunlop.
Well see how they hold up. I had 1300 mi. on my old set up.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
I need tungsten balls fasternat Enduro Engine - 2 stroke 5 10-19-2009 01:31 AM
Tire stand for moose or tire balls kim Enduro Other... 6 12-28-2007 12:12 AM
Got Balls ?? FFRDave Enduro Chassis & Body 4 02-11-2007 11:37 PM
Tire Balls MIKEWA Enduro Product Reviews 4 11-06-2006 02:39 PM
