Old 01-09-2014, 12:19 PM
liv2day's Avatar
liv2day liv2day is offline
Originally Posted by noobi View Post
So, your gut feeling of a change of 50:1 to 60:1 making sfa difference is correct.
Great job on the math; I started to get a slight ice cream headache (lol), but I like the flow of the logic.
I'm going to get into the carb this weekend and see what's what - been putting it off and need to do it anyway. I think an interesting test would be to try 60:1 and see if there's any noticeable difference - might do that too on the next ride.
Thanks for all the responses gents
Old 01-09-2014, 07:28 PM
noobi's Avatar
noobi noobi is offline
Originally Posted by Zman View Post
Very Well Done! What are your thoughts on the difference in viscosity?
In respect to what specifically?
Material properties of miscible fluids are typically additive.
In the same way that density was additive for the previous example.
Gasoline isn't particularly viscous around 0.4-0.7 cSt at 40C, infact its generally less viscous than water.
Where as 2 stroke oils are around 45 cSt at 40C.
So the difference in viscosity is about 90 times in favour of the oil.
Lets consider a mix of 50:1, or 2%
0.98x0.4 + 0.02x45 = 1.29 cSt, so you've tripled your viscosity by adding 2% oil.
As for your previous comment on the reduction in octane by adding oil, that is again due to the additive nature of miscible fluids, the gasoline has a octane number of say 90. The oil has a much much lower one, probably zero, but lets say 4 for the sake of the example.
So when you mix at 2%, 0.98x90 + 0.02x4 = 88.3.
So by mixing at 2% you have reduced the octane rating by ~2 points.
Thats why you will have read about reduced octane ratings in premix.
Old 01-10-2014, 07:00 AM
Zman's Avatar
Zman Zman is offline
I was thinking that a more viscous fuel would require a higher amount of airflow to be drawn through the carb, resulting in a leaner condition.
Old 01-10-2014, 07:38 AM
Fred1956's Avatar
Fred1956 Fred1956 is offline
I run Amsoil Dominator (not Interceptor) at 50:1 with no spooge but I'm also using a Leo Vince with spark arrestor. I believe Interceptor has a higher flash point than the Dominator, that coupled with the Q could be your issue.
BUT I agree if throttle response is good then carry a paper towel and wipe the sponge on occasion.
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 01-10-2014, 08:46 AM
mjtursky mjtursky is offline
Default Correct Oil ratio
This is getting pretty deep into the science. My opinion on this is not to run higher than 50:1 oil ratios. You will give up engine life with mixtures higher than this. When testing outboards with variable injection, the engine can tolerate leaner oil mixtures (up to 100:1) but it will require richer mixtures (40~50:1) to maintain proper lubrication to critical parts of the engine. Since we are running premix on our GasGas I would recommend staying with 50:1. Once this is defined you can focus on the correct carburetor setting to optimize performance.
Old 01-10-2014, 11:30 AM
liv2day's Avatar
I ran Dominator initially, but switched to Interceptor after reading what I think to be the exact opposite...lol. I haven't double checked yet, but I think the Dominator has a higher flash point as it's more meant for racing. The Interceptor is targeted to the trail rider who isn't reving the engine as much (again - if memory serves me...which is always a big if now...lol).
When I have time this weekend, I'm going to pull the carb and check the jetting....need a base line
Old 01-10-2014, 11:51 AM
andoman's Avatar
andoman andoman is offline
Default Wait: I'm confused...
Isn't that backwards? Since octane rating is a measurement of resistance to combustion (specifically used to analyze flame front propagation) wouldn't the oil bring a HIGHER overall octane rating to the mix? Especially one like Motul 800 with a flash point 3 times higher than the petrol it is mixed with?
You assumed an octane rating of 4 (perhaps as low as zero) for the oil: wouldn't that low of a rating indicate a dangerous propensity to spontaneously combust?
I apologize to all for hijacking the thread earlier. Cudos to fred, mjtursky, and livtoday for helping to get us back on topic.
Having said that, I still appreciate noobi's willingness to explain things. Though I have a hard time following the science, I find it absolutely fascinating. Thanks.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 01-10-2014, 12:13 PM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
My 2012 has no spooge problems and I am using GRO at 50:1.
I have the bike jetted slightly rich (safety), and have great throttle response everywhere.
Cheers Mark
Xr 250 ( first bike)
98 Rmx
2007 Gas gas 300(swapped for trials bike)
2008 280 Raga replica
2012 Gas gas ec 300 E
Old 01-10-2014, 02:13 PM
gasser's Avatar
gasser gasser is offline
I run Amsoil Dominator (not Interceptor) . I believe Interceptor has a higher flash point than the Dominator,
Actually Domiminator has the higher flashpoint but the difference is very small and both are on the lower end of the flashpoint spectrum of the top synthetic oils. I have never ran better oils, yes there are some that are just as good but none (here in the U.S.) can I get as cheap as Amsoil.
Old 01-10-2014, 06:54 PM
noobi's Avatar
No problem, I haven't needed to explore this stuff mathematically before, so its interesting for me too.
You've kind of jumped the gun a bit by saying octane is a resistance to combustion, although that's an effect of higher octane numbers. Its a reference to the activation energy of the combustion reaction that must be overcome by work done on the mixture. Work is done on the mixture by compression, it loosely obeys PV=nRT, and as volume decreases pressure increases, but temperature also increases. A lower octane number mixture requires less work to be done, so the activation energy is overcome at a lower pressure than a higher octane mixture. Hence the resistance to combustion.
Now when the spark goes off, there is a localised hot spot where the spark has arced, and that is what overcomes the activation energy and causes combustion.
Now oil doesn't combust under compression alone, so an octane number doesn't apply. So when you dilute the gasoline with oil, the overall mixture volume has a lower octane number because the oil doesn't contribute to it.
Also, flash point does not mean ignition, specifically it means the point at which it becomes a combustible vapour. So an oil still requires an ignition source once in a vapour state. Gasoline doesn't necessarily.
As for viscosity increases, I would say it is possible that you could have a reduced flow through the jets if the viscosity was increased by a large enough amount. I feel that that would be incredibly difficult to model.
Hope that helped a bit.
Looking for a key switch.... Novascotiarider Enduro Electrical & Wiring 1 07-06-2013 07:21 AM
map switch shark4465 Enduro Engine - 2 stroke 1 11-18-2012 06:12 PM
map switch, in or out? solstice Enduro Engine - 2 stroke 4 03-16-2012 11:14 AM
Switch Rabbitist General Discussions & Announcements 1 05-24-2011 07:10 PM
Dual Map switch.. stevehipkiss Enduro Electrical & Wiring 3 01-28-2010 01:29 PM
