Old 07-07-2019, 02:34 AM
Dan Dan is offline
Default 2013 rad leak
Really not having any luck with my bike right now. Does anybody know which other years or models may fit a 2013 ec left hand side rad
Old 07-07-2019, 05:44 AM
Gasser Nate's Avatar
Where is the leak? Might be able to get a competent welder to tig it.
Old 07-07-2019, 08:00 AM
Pygmygod Pygmygod is offline
Have a bit of a search but in my recent googlings all EC models from a span of about 15 years all fit each other
Old 07-07-2019, 09:54 AM
Dan Dan is offline
I have a video of where the leak is and according to the guy that was going to weld it it can?t be saved.
I have managed to find one from an 02 model on eBay but have no idea if it is going to fit and can?t seem to find a definitive answer anywhere online!
Old 07-07-2019, 10:05 AM
Dan Dan is offline
This is a screen shot from the video as I can?t upload the video to the site not sure how good it is or clear
File Type: jpg ED2B37A3-1BCB-4CEE-9B7D-DAB068103436.jpg (5.7 KB, 12 views)
File Type: jpg 63958902-456E-4010-BD13-B0C9CB62DEC3.jpg (7.3 KB, 9 views)
Old 07-07-2019, 11:58 AM
Anders's Avatar
Anders Anders is offline
The 02 and 2013 rads are different, but I presume you can make it fit if that is your only option. You might also try your luck with the chinese rads on ebay.
Where are you located? There may be someone breaking a bike in your country. I could send you one from a 07, but postage will be very expensive
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 07-08-2019, 05:22 AM
Wimpy525 Wimpy525 is offline
Where are you located? I have a set of Radiators for a 13 EC300 with BRP guards, a bit twisted but don't leak. 200 for the pair with the BRP guards.
Old 07-08-2019, 06:05 AM
Checking the parts listings on here: https://www.motocrosscenter.com/shop...diators-grills
Looks like 2000-2005 are the same as each other.
2006 is an odd one out.
Then 2007-2017 are another design.
If I were you I'd be buying the China ones off eBay if you can't find a decent used pair.
Have read about several people using them and they said they are fine.
Old 07-08-2019, 08:03 AM
Biff's Avatar
Biff Biff is offline
I've had the cheap ones off Ebay and there
fine. If anything , more robust than OEM
Old 07-08-2019, 01:52 PM
+1. I have a set on my '05 300 and they work great.
Coolant leak welsh.Z.S. Enduro Engine - 2 stroke 10 03-27-2017 12:29 PM
Radiator leak Buysomerice Enduro Engine - 2 stroke 10 10-06-2014 09:34 PM
Weird one - oil leak blitz11 Enduro Engine - 2 stroke 2 09-25-2012 12:12 PM
Leak leak leak... AnthGG Enduro Engine - 2 stroke 4 12-15-2011 08:10 PM
Gas cap leak? colinmc400 Enduro Chassis & Body 6 05-21-2007 07:09 AM
