Clutch dragging - replacement advice please
I believe one or more of my clutch plates has warped and the clutch drags even with the lever down to the bar.
This meant I failed to get off the line first kick at a race this sunday and also I was stalling 15-20 times in the race - not good. The bike idles fine in neutral but stalling in gear with the clutch pulled. So my questions - has this happened to you - what was your fix? Is it common to warp plates? Should a new clutch mean there is no drag at all in gear with the clutch pulled? A while ago it was dragging a little and I thought I could tell one plate was a bit warped by laying it on a bench - is this a good or reliable method? The others looked flat. I was using 10w40 petrol engine oil - could this have contributed to them warping? The advice I get off everyone who runs this says it's fine... I will probably end up with a DP replacement clutch - are these good?
'05 Gas Gas 300 '97 Aprilia Pegaso 650 '99 KTM 200 '95 ish XR630 (died many times in Oz) |
Need advice please | gascanuck | General Discussions & Announcements | 2 | 12-15-2009 07:26 PM |
Tools for clutch basket replacement | SpeedyManiac | Enduro Engine - 2 stroke | 4 | 09-19-2009 07:04 PM |
Clutch basket replacement | SpeedyManiac | Enduro Engine - 2 stroke | 2 | 05-14-2009 08:26 PM |
Clutch disc replacement | Betim | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 05-26-2007 06:53 PM |
WP advice | Brian VT | Enduro Suspension | 30 | 05-02-2007 07:13 AM |
