Old 08-31-2013, 12:09 PM
schlitzy schlitzy is offline
Default 2012 300 e start issue
It will kick start, kill button works, key will shut off the motor but no lights and the e start won't work with the button. I can use a screwdriver to jump the relay and get the starter to turn. The battery checks out. Both the fuses on the relay look good. When I got the bike I had the same problem that turned out to be a fuse on the relay, but like I said they both look good? Is there another fuse elsewhere? This happened during a ride in wet/rainy conditions.
Thanks
Old 08-31-2013, 02:18 PM
timlh's Avatar
timlh timlh is offline
Just a thought did you just visually check the fuse or use a continuity tester ? I have found many a blown fuse that looked good.
If you don't have a meter or continuity checker then just try replacing both fuses. The bigger question is if its another blown fuse what is the root cause ?
Old 08-31-2013, 03:07 PM
Great minds think alike. The last time it happened I bought a handful of fuses so I just changed them out and "presto", 1st problem solved. As to the cause, I now think the first time was caused by the brake light function of the rear light shorting out. I cleaned up the bike and the rear light housing looks like there was mudwrestling going on inside it. I'm guessing it's not very well sealed up.
Thx
2012 Gas Gas 300 E-Start SMSRacingJosh New Bikes 0 01-16-2013 02:11 PM
2012 300 issue bones150 Enduro Intake/Carburetion - 2 stroke 7 06-22-2012 12:29 AM
