Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Trials Technical Forums > Trials Engine
Trials Engine Cylinder, Piston, Tranny, Bearings, Clutch, Pipes & Silencers, etc.
Old 03-18-2017, 03:15 AM
Oystein00 Oystein00 is offline
Default Engine block hole
Hey, everyone
New to this forum! I just started doing trials and recently bought a Gasgas 125 TXT Pro Racing from 2011. Presumably in good condition, but after a couple of months I found a hole in the engine block, left split. It is located under the flywheel (I think it's called) - it's adjacent to the coils that generate power to the spark plug. Result is that engine oil is leaking out the hole and into the "compartment" where the coil sits. Or, the oil that's leaking is meant to lubricate the crank shaft bearings? I cannot really estimate the rate of leakage.
Does anyone have any good tips for how to fix this, besides the obvious and expensive solution of replacing the block entirely? I also cannot see how this would occur, apart from a manufacturing error?
My current idea is to use chemical metal (Loctite 3450), but would really appreciate any input you may have!
Attaching a few photos.
Cheers.
Old 03-18-2017, 05:28 AM
Nocams Nocams is offline
How'd that happen?!?!
epoxy type liquid metal would be my choice.
clean with brake cleaner or thinners and scratch the hell out of the surrounding area for a good bond.
Old 03-18-2017, 06:44 PM
Thanks for the tip! The one I have is epoxy with steel in it.
As I said, I have no idea how it happened. Only thing that makes sense to me is a manufacturing error..
hole in engine????? lonetree Enduro Engine - 2 stroke 2 10-19-2011 08:43 PM
Small hole in bottom of engine ??? vgstef Enduro Engine - 2 stroke 1 01-17-2011 03:17 PM
Ken Block...at it Again! Rick Pictures & Videos 5 11-06-2009 11:56 AM
M6 hole under engine? moff747 Enduro Engine - 2 stroke 2 03-19-2008 10:48 PM
07 GG300EC - small hole at btm. of engine? g dirt Enduro Engine - 2 stroke 4 02-26-2008 05:48 AM
