Old 09-30-2017, 12:37 PM
70455gto 70455gto is offline
Default 1999 EC250 crank spins relative to bearing race
Hello
I have a 99 EC250 bottom end I am using instead of rebuilding a 2002 bottom end that grenaded transmission gears from PO.
The 99 has radial play between the crank and bearing, clutch side.
I ink marked the crank and bearing inner race. With 5 rotations by hand, the ink marks are ~15 degrees apart.
Do I attempt to have the 99 crank welded up/plasma sprayed and machined for proper fit? Or do I put the 02 crank in 99 cases?
Who has dealt with this situation?
Thanks!
Old 09-30-2017, 01:23 PM
Also, 99 model crank has a full round crank weight. 01 model crank has a 2/3rds crank weight. Is the 02 off balance requiring this off center deaign? I assume I need to keep each weight with each crank.
https://flic.kr/p/XYTCC4
Hopefully the image links, if not I will look for url/image thread. 1st image upload on flickr since photobucket ransom event.
Thanks
Old 09-30-2017, 01:26 PM
https://flic.kr/p/XYTCC4.jpg
Old 09-30-2017, 01:29 PM
[img] https://flic.kr/p/XYTCC4.jpg [/img]
Old 09-30-2017, 01:31 PM
[/url]
Old 09-30-2017, 01:32 PM
Tags
bearing, crank, radial, spins
Crank bearing failure .WTF ? Getoviq95 Enduro Engine - 2 stroke 2 04-16-2017 01:27 AM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
Crank bearing help please!!!!!!! Porkyblader Enduro Engine - 2 stroke 2 09-09-2011 04:46 PM
07 Crank bearing... NEED URGENT HELP. wence Enduro Engine - 2 stroke 11 05-23-2010 02:25 PM
2007 EC250 Crank Bearing? BIG TOOL Enduro Engine - 2 stroke 9 11-23-2007 02:47 AM
