Kickstart problem
Just rebuild the bottom end of my engine but it all back toghether had a bit of an issue with tranny oil and water mixing but thats all sorted the only problem i have is its like theres no tension to my kickstart i can kick it fine but it wont tension back, the spring is all on properly what should i do?
2001 Gas Gas EC250 Supermoto Boyesen Pro Series Reeds, Messico & Modified FMF TC II, Black Powdercoated Wheels & Hubs, Red Renthal Fatbars, Polisport Handguards, 4 POT Brembo Front Brake W/ Floating Rotor Want: Doma,Messico Or 06 GG Front Pipe, RB Carb & Head Mod, DE250, XC250 Or EC200 CDI (If you have any of these parts PM me!) |
Check the plastic bushing that resides in between the shaft and the spring and make sure that the relief slot in the bushing is properly indexed on the spring.
gasser250sm,
I am no expert, but there are two springs. The one that is 'weak' and pushes the gear up, and then there is the spring that provides the tension, or the force that brings the kickstarter back to the 'rest' position. I believe that this spring can be installed in multiple positions. Too much one way provides to weak of a return, too much the other way provides for a extremely strong return. I don't know if you can tell it's right or wrong until you install the kickstarter and give it a try. I put my kickstarter on before I put he case side on just to test it. I think I installed it a little too strong, but the enemy of good is perfect. Just my info. Hope it helps. GasGasDreamer
2002 Husberg FE650e 2006 GasGas EC300 2014 Sherco SER300 2014 Beta Evo Factory 300 |
how do you remove the kickstart | noobi | Enduro Chassis & Body | 13 | 09-22-2011 03:31 PM |
kickstart swap | Trailrider | General Discussions & Announcements | 9 | 07-29-2010 12:33 PM |
04 ec200 kickstart lock | warnzie | Enduro Engine - 2 stroke | 5 | 07-28-2008 06:27 PM |
Kickstart | steve | Enduro Engine - 2 stroke | 6 | 04-08-2008 03:09 PM |
