how do you remove the kickstart
im assuming its supposed to be simple, but it isnt.
i cant get the kickstart pedal base off the shaft, it wont even budge |
Should be simple. Remove the keeper bolt, then rock the kick lever off it's splines. It may take a few smacks with a dead blow hammer to free any electrolysis. Other options would be to use a puller of some sort. Spray the splines with a good penetrant and let it sit. Heat works good too.
Mike Sheetz OMRA #21AA What will I be riding next? Christini GG 300? '15 KTM 300 XC-W '08 EC 250 (Gone to new happy owner) Gran Prix Cycle LTR Suspension RB-Designs |
The knuckle seats on the taper of the shaft. Even with a clean, antiseized assembly its a bitch sometimes. Get yourself a decent two jaw puller. Thread a short M6 cap screw in the end of the shaft to protect it and give the puller screw something to center on. If its never been off and/or seized some heat may be needed.
Most bikes viberate,loosen and wear out on the spline or retaining bolt falls out and ks gets lost in the mud. |
Hoping someone can help with anymore ideas on this one??
I have tried all of the above, heat, levering and wd40 and still no luck. Is there anything else I can soak it in other than wd40 to try and loosen the teeth?? Frustrated!!! |
I had the same problem with a 2001xc300 I used to have. I bought it used and it had a Yamaha kick starter on it. After pulling my hair out I finally discovered that it had a small allen set screw in the knuckle. Once I loosened it the kick starter came right off.
spray it with 50/50 atf/acetone mixture.
if you're totally stuck., go to your local decent automotive parts/tools store, and ask for a battery terminal puller. small enough to fit i would guess. i'm betting that will get it off. and it's a handy tool to own. pulls small gears with ease.
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com Last edited by stainlesscycle; 09-21-2011 at 08:50 PM. |
A while ago now, but I used a lot of heat, combined with ENOX? and just tried many different ways of levering it until it broke free.
The splines were all full of junk and crap, cleaned those out and its good now. |
Mine has tried to jump off and get lost in the woods twice already. I have put locktite on both bolts and still have had to buy the bolts and check balls on two occasions. Be glad that yours stays on.
Remove front axle | BULTACOBRIS | General Discussions & Announcements | 2 | 03-10-2009 10:28 AM |
Kickstart | steve | Enduro Engine - 2 stroke | 6 | 04-08-2008 03:09 PM |
How best to remove carbon from PV components? | d2w | Enduro Engine - 2 stroke | 9 | 02-21-2008 09:03 PM |
Periodically remove and re-fit all bolts? | stay_upright | General Discussions & Announcements | 2 | 01-14-2008 07:56 PM |
What's the best way to remove the master link plate after it's pressed on? | MattR | Enduro Chassis & Body | 12 | 01-28-2007 12:15 PM |
