Km to Mph for 04' GG 450FSE
Anybody know how to change from Kilometers to Miles-per-hour for 04' GG? Thought it was something with a chip upgrade on the display but apparently not.
Thanks, -Chris |
Copied from the manual.
You can download it here: http://www.gasgasmotos.es/rcs/manual...04_fse_eng.zip Quote:
Great, Thanks. I will give it a try.
I have an 05, and that did not work for me.......anyone else try that?
Keep trying, it works
Dont follow me, You wont make it. |
Does that work for ealier years also? (03?)
John B. '03 GasGas FSE 400 '97 Honda CR 250 '02 Honda VFR800 |
It works on my '03.
Yes, keep trying!
Also, if you don't already have a Battery Tender wired on the bike - Do It Now, my plug is ty-wrapped to the frame, just inside the air box door so it's quick and easy to access which is important on a bike that NEEDS to live on life support (maybe it doesn't IF you can ride it often). Perhaps someday I'll look into adding a switch to turn off the speedo, etc. and the battery will last more than two weeks, kind of busy right now so it gets ignored, and doesn't like that much. Bruce
No one ever calls the Fire Department because they did something smart |
Also the battery tender keeps your battery fresh thru the winter. If U don't use one during this weather period U will be buying a new one. Ask me how I know.
'14 Beta 300rr '05 GG DE300 '03 GG EC250 '01 XR440 '09 FZ1 |
Well, after my second attempt, I actually did get MPH to register on my speedo. Next question is, does the ODO still read in Km., or does that switch with it? I'm thinking it stays in Km., but not sure. It would just be nice to know if my bike has 500 Km.s or 500 miles on it for examle.......
slip-on 450fse? | johanpe | Enduro Engine 4 stroke (including EFI & Exhaust) | 11 | 07-26-2010 11:24 AM |
oil sensor 450fse 03 | jjbaker1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 03-12-2009 05:54 AM |
450fse tuning | jjbaker1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 9 | 03-09-2009 04:40 AM |
