Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Archive of For Sale Forum
Archive of For Sale Forum Old Common For Sale Forum (Temporary)
Old 06-01-2013, 01:59 PM
einsteingarage einsteingarage is offline
Default Tubliss tire system - $75 for both 18 and 21 inch
Used 18 and 21 inch tubliss tire system. $75 for both
Old 06-01-2013, 02:34 PM
roverhybrids roverhybrids is offline
Whats the condition?
Do these wear out?
2011 GasGas ec300R
2011 GasGas ec200 Six Days
Old 06-01-2013, 08:17 PM
Rick's Avatar
Rick Rick is offline
Do these wear out?
You need solid rubber tires for up there in Shasta country That place is hell on tires and tubes?! I have never seen so many eembedded rocks in may life.....sharp ones....
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 06-01-2013, 10:37 PM
Brian VT Brian VT is offline
All rocks here and a couple of my buddies have had good luck with them. It's pretty neat to see them just put a plug in, reinflate, and keep on riding.
Old 06-01-2013, 10:42 PM
Front Royalty's Avatar
Front Royalty Front Royalty is offline
Pm sent on the tubliss
'07 GG EC200
'03 CR250
'01 Honda CBR600F4i
'06 YZ250F parting out...
Old 06-01-2013, 11:45 PM
If there are lots of sharp rocks you need to go for a strong sidewall tire (mitas ) to avoid cuts that are v hard to plug
In terms of wearing out the red liner can stretch (after a few years) and/or get damaged by tire irons
The rubber around the valve clamp can get worn (also after a few years) and the inner tube can also get old and pop (it is at 100 psi so advisable to replace once a year just to be safe about $8) but all of these parts are available and reasonably priced and should
2003 txt250 Pro
2013 Ossa 280i
Old 06-02-2013, 05:16 PM
Sale is pending
Old 06-03-2013, 08:09 AM
GMP's Avatar
GMP GMP is offline
Most common Tubliss problem is grabbing the liner with the tire spoon when removing the tire, and damaging it if you do not realize this and stop. This is because the liner tends to stick quite well to the inside surface of the tire even after the inner bladded is deflated, especially when using slime. There are tricks put its still a PIA with some tires. I'm working on a special tool to safely separate the liner from the tire without ruining it. Once the liner is free of the tire it retracts into the drop center far enough and is no problem as long as your tire spoons are clean and free of burrs and nicks. Keep them clean and smooth and you will have no problems.
I really like this system, and will not go back to tubes. Plus, if you have ever talked to Jeff, he is a model for customer service. Mousses are just too $$ and too much work for me.
Front tire suggestions? Tubliss? lankydoug Enduro Chassis & Body 13 01-07-2011 11:50 PM
Tubliss with trials tire roostafish Enduro Product Reviews 34 07-22-2010 04:06 PM
Trials Tire + Tubliss? MIKEWA Enduro Chassis & Body 7 03-18-2008 06:03 AM
