Old 04-13-2023, 06:45 AM
Noobi06 Noobi06 is offline
Default Cylinder clearance
I am sending in my cylinder for replating. Since I am riding on roads, they adviced me to have my cylinder 0.1mm larger than the piston. Usually, you have about 0.05mm. This is to prevent the rings/piston from catching the wall (heat pinch). It happens sometimes on the road when you switch gears and a lot of people have gotten it when driving up hills etc.
What do you guys think about it? He says it is good and I understand his reasoning, however I am scared that I will loose power.
How much horsepower do you think I will loose? I have about 39 and I do not want to loose too much.
However It will be safer for riding. Can it give other consequences?
Thanks guuys
Old 04-13-2023, 10:04 AM
Darkside Darkside is offline
I'll admit, I have never heard of that. what would road riding have any difference to dirt riding in terms of the engine? personally, I would stick with the factory recommended clearances.
2006 GasGas EC300 2011 KTM 300XC
Old 04-13-2023, 11:20 AM
Anders Anders is offline
Road riding will in many cases mean longer periods with wide open throttle, hence higher mean temperature.
A125cc ridden by a youngster on the roads is usually ridden harder than you would do off road.
Old 04-13-2023, 04:20 PM
SS109 SS109 is offline
I have never seen nor felt the need to increase piston to cylinder clearance for running a 2T dirt bike on the road. Lots of my club members dual sport and/or have their 250/300's street plated here in Arizona. We've done highway miles and fast dirt roads and I've never seen any bike seize up running stock clearances and on some bikes running as little as 60:1 fuel/oil ratios. The key is in your jetting. Always be on the rich side if you plan on dual sporting your 2T.
Old 04-13-2023, 04:21 PM
Do you guys think I should do what he adviced? 0.1mm clearance. This would decrease the risk off heat pinch. According to him, many with the same gasgas ec 125 have driven like 60kmh and from nowhere gotten a pinch so I assume it would be a great idea.
I just dont want to "throw away power". At the same time, its for the better
Old 04-13-2023, 05:18 PM
For a 125, maybe it is a good idea. I might increase it a bit but what they're recommending just seems excessive to me. I would think .07 or .08 and those are some big clearances IMO/IME. I guess, however, I would defer to them if they have actual real world experience with the Gasser 125's.
Old 04-14-2023, 10:38 AM
Thanks for the answer. Ill got in the middle at about 0.075
Old 04-15-2023, 10:49 AM
with more clearance you might get more piston slap. especially as it wears. might need to replace the rings more often
Old 04-15-2023, 11:59 AM
Yeah I was thinking that aswell
Old 04-17-2023, 02:10 PM
Okey so apparently the cylinder has a cast iron lining which is really bad. We are going to replate it either way and I am going to run a forged piston inside. Bore is going to be 54.5 and piston is going to be 53.5 or 54, something like that.
Now what I wonder is how bad this cast iron lining is? Its an old way of doing this that some owner had done.
How much will it affect the lifetime of my cylinder/pistons?
Clutch Master Cylinder with More Bar Clearance sneaky98gt Enduro Chassis & Body 6 06-28-2018 06:20 AM
powervalve spacer clearance Adam500 Enduro Engine - 2 stroke 6 04-13-2017 07:47 PM
Graphics Clearance Harry Enduro Chassis & Body 1 11-26-2012 09:29 PM
powervalve clearance jeffs2200 Enduro Engine - 2 stroke 13 08-31-2012 10:44 AM
