Old 07-16-2010, 04:16 PM
fkmf6 fkmf6 is offline
Smile overheating problem please help
i have an 05 fse 450 with 840klm's on the speedo. bought it 3weeks ago as a spare bike and ridden it twice, my problem with it is that when it idles for more than 2minutes it pisses coolant out of the overflow tube onto exhaust header, the fan doesnt come on at all even if it boils, there are no signs of water in the oil so i dont think it has done a head gasket, when it runs hot the performance suffers a little. starts first time every time so with minimal klm's on it what could be the problem? should i run a colder plug in her? the bike sat for four years in my mates shed before i bought it flushed the old coolant with new coolant new oil new plug, bike was dropped previously on right hand side radiator and has dent in it next to fan cuold that cause it, any suggestions or advice would be greatly appreciated
Thanks jim melbourne australia
Old 07-16-2010, 04:41 PM
gasmonkey's Avatar
Bronze Level Site Supporter
First off, sort the fan issue out.IME check fan relay and wiring.Check that fan works (temp wired to 12v source).Check that connection is clean etc on the sensor at rear of motor.The sensor operates the fan via the ecu and relay.
Ive replaced a burnt out fan and the rest is generaly reliable.I use plenty of wruth electrical contact cleaner too.
Old 07-16-2010, 04:55 PM
bergerhag's Avatar
Replace the radiator cap. Seen many gg 4-strokes with this problem.
Old 07-16-2010, 05:09 PM
thanks bergerhag done that with a cheap replacement made it worse then put on a original for 3 times the price and seems a bit better
Old 07-16-2010, 06:24 PM
thanks gasmonkey fan seems not to be working tried to earth it out and nothing is happening
Old 07-16-2010, 07:56 PM
Besides the fan issue, check your impeller. Some were a poor grade plastic that broke down even in the cooler running 2-strokes. Consider EVANS NPG R coolant. No FSE here but it tamed my steamy Cannondale making it ridable in the woods.
Old 07-17-2010, 01:02 AM
bergerhag's Avatar
To test run your fan, either use the Technoresearch software or remve the fan relay and jump the connectors. Bike must be running or at least ignition on in the priming phase. For a quick relay test, just swap the two. If the fan relay is bad, then bike wont start if you swap them.
Old 07-17-2010, 08:30 AM
East_TN_GG's Avatar
East_TN_GG East_TN_GG is offline
isnt there a ktm oem radiator cap that is supposed to be good for the 4t's?
Old 07-17-2010, 08:47 AM
iancp5's Avatar
iancp5 iancp5 is offline
Yeah but if it's happening when it shouldn't might be worth finding the cause.
Old 07-18-2010, 08:04 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
Make sure its on the "real " map not the one that passes emmisions. That map runs so lean the exhaust header glow red and will make the engine run real hot.
06 Gas Gas FSE 450 USA
07 Gas Gas FSR 450 UK with motard and dirt wheels
FSE450 overheating question GregM Enduro Engine 4 stroke (including EFI & Exhaust) 20 10-28-2009 05:21 PM
Ec 250 Overheating New Piston? Elliker Enduro Engine - 2 stroke 6 07-16-2009 04:55 PM
Overheating 300 in climbing mariogt Enduro Engine - 2 stroke 11 12-04-2008 03:49 PM
A few questions (overheating) 2 strokes 4 life Enduro Engine - 2 stroke 8 06-03-2008 09:13 AM
I think I have a problem SpeedyManiac General Discussions & Announcements 7 11-30-2007 11:26 PM
