Old 03-27-2019, 05:51 AM
frankinberg's Avatar
frankinberg frankinberg is offline
Yes those are 45mm zokes
They were used on early ktms to 95
Old 03-27-2019, 08:41 AM
CDN Rick's Avatar
CDN Rick CDN Rick is offline
Originally Posted by Banditpowdercoat View Post
I will be emailing Langs shortly for one. Already found the swingarm and linkage bearings from All Balls. One thing I don;t know is brand of fork? It's a Ohlins rear, but not sure on fork as the oldest manual I have found is for 2003. There regular right side up forks, with blue compression knob on left, rebound knob on right stanchion. Left fork seal is weaping a little.
Prev owner was a fat kid, 250 or more in street clothes. I am 200. He changed springs, but kept the stock ones. I know the rear is cranked up to much, no bike sag and only 40mm or so with my arse on it. It is cranked down over 3/4 way on adjuster, so may just try loosen a bit before I replace. I ride single track, and overgrown forestry roads, washouts etc. Basically anywhere in the BC Canada Mountians. Not at bike parks or tracks.
As already stated. Those should be MarZoks...
Rob is also a the ONLY registered Enduro Engineering Suspension Tech in Canada. He should be able to help you out with the suspension stuff as well.
2018 GasGas EnduroGP250
2018 GasGas TXT GP300
1994 Honda CR500 (Ice Racer)
Old 04-06-2019, 06:46 PM
Banditpowdercoat Banditpowdercoat is offline
Ok. Took her for a little rip today. Just 4 miles up and back a logging road and such. Thought I'd share a pic
Old 04-07-2019, 05:26 AM
RBrider's Avatar
RBrider RBrider is offline
Thumbs up
The pipe on my '01 XC 200 looked like yours when I got it. And fit about like it looked, which was not very good. I found a new old stock, unused FMF Gnarly on EBay for $201US including freight.
You might find something like that for your bike, if you keep your eyes open.
Matter of fact, I've bought everything I've needed for my 200 off EBay , or sites recommended on this forum & one Euro onlne GG dealer That I had good luck with.
RB
Old 04-07-2019, 08:35 AM
Zman's Avatar
Zman Zman is offline
That bike is a winged unicorn! Unless someone removed it, it has the counter balancer and it is silky smooth! It should also have the "real" lighting coil that will run ~125W instead of the silly small 35w on most other GGs. It has the Messico pipe that is excellent and I would personally get it fixed instead of replacing it with a fmf. It also has the steel subframe which is a little heavier but it is stronger than the aluminum one and is not likely to crack. Les at LTR told me that those forks are very simplistic inside and work fine for trail riding but are not well suited for track use or serious enduro riding. We have a pair of them on one of our 1998 EC250s and after a oil and seal change they work fine for the purpose.
Congrats on the purchase! Let me know if you ever want to sell the bike!
New Gas Gas Owner gasgasbloke Enduro Engine 4 stroke (including EFI & Exhaust) 23 10-12-2013 07:15 AM
hi from the uk. not yet a gas gas owner ohffs General Discussions & Announcements 6 08-24-2013 04:14 PM
New owner of a 99 EC 300 boardrider247 General Discussions & Announcements 12 07-11-2013 07:04 PM
New owner, Have I got this right? daw003 Enduro Chassis & Body 5 02-18-2012 10:41 AM
New EC/O 200 Owner lankydoug General Discussions & Announcements 3 08-02-2010 09:30 AM
