#11
OP said that he hears the noise when revving the bike on stand, so likely not chain slap. A video would likely help determine the root cause.
#12
I will do a video next week. I think that the knocking could be beacause of the N1EF needle. I want to try other jetting. i read a lot of posts but don't know were to go. Here in my area(Portugal) we don't have to much elevation, is about 0-500m and i have all types of terrain, woods, deep sand and fast open roads. I see some riders using: pilot 42, NECW #3, main 175, AS 1.5 could be the right one for me?
#13
https://youtu.be/6JaEs8JFaeI |
#14
#15
Quite possibly, but after looking at your video I would be fixing all the bits that are flapping around first...
Back on a gassy! 2018 EC300! 🤘 Txt 280 07 to make me feel like a gumby again |
#16
Loose motor mounts? As was said, lot's of flappy parts.
#17
Same here. 4 bikes two 18's and two 19's they all had it. Made me crazy but now living with it.
I think it is pipe bang, most of the time it appears when going steady and slowly or inadvertently close the throttle just a tiny bit. Bang! Sounds like a hard knock and comes from the cylinder outlet area. I tried this for hours and it also appears when going downhill with closed throttle or just after the throttle has been closed. I first thought that pieces of branches or stones hit the bike on its plastic bash plate but it appeared always on the same spot of a 15 minute lap. In the meantime I can live with it, but I can remember that I was really pissed off when I first heard it and was unable to find it though I spent hours and hours.... |
#18
Did you resolve it?
I had a knock on certain revs, 18 bike also, riding bike in slow terrain, so no overreving, 65hrs total engine, with new piston 2 hrs. Well, knock suddenly increased at some slow descent and stalled the bike. Didnt try to start it, had it vanned home. Dismantled, saw some scoring on cylinder wall, which just yesterday went away with honing. Culprit, so it seems, but have yet to make me a crankcase puller, is the main bearing failure. May I also say, that I lowered the needle by 1 on N2ZJ, and reduced the pilot 45 to 42 prior to ride, since plug was black from previous ride. When returned, it was quite whitish, and vent was coming on much too soon during the ride. So leaner condition and failing bearing kind of coexisted and lead overheating and destruction.
EC 300 2008 EC 300 2018 GP tenere 700 |
#20
Ec300 2015 stalls on high revs | matanstolero | Enduro Intake/Carburetion - 2 stroke | 9 | 05-21-2018 08:18 PM |
EC300 maximum revs | WAZ | Enduro Engine - 2 stroke | 6 | 04-07-2014 10:11 AM |
New 2010 EC300 Engine Noise (falling revs) | Jakobi | Enduro Engine - 2 stroke | 11 | 11-16-2010 06:41 PM |
EC300 Revs when cold-started | stevethebrit | Enduro Intake/Carburetion - 2 stroke | 6 | 07-10-2009 11:04 PM |
low rpm/idle knock | joey11 | Enduro Engine - 2 stroke | 13 | 07-10-2008 07:42 AM |
