Harder spring for Marzocchi 45mm
Hi,
have a problem to get harder springs for a EC125 -10. The spring is 470mm x 40,6mm. Is a standard spring for now. I think it is for 75kg. We need springs for 85kg person plus gear, so 95kg. Have some one a idee where I can get this? Live in Sweden. Thanks / Michel |
BetaUSA's online web shop has springs listed for the Shiver 45's. https://shop.betausa.com/p/fork-spring-45mm-marzocchi I'm sure someone on here will be able to help with what spring rate you need.
k tech uk or s tech Germany or ebay
I found some s tech in Germany
Thanks for your inputs. Michel |
i looked on ebay 105 e
Just a thought.... |
That is not the case for the 45mm Marzocchi, only the 48mm PFP fork on later bikes
Yeah, 2010-2011 Beta RR and RS models. They will fit any 45mm Shiver fork.
Thread Tools | |
Display Modes | |
Marzocchi 45mm settings | Russmann | Enduro Suspension | 7 | 06-01-2020 09:01 AM |
Marzocchi 45mm Forks | mcnut | Parts | 9 | 01-12-2016 10:23 AM |
marzocchi 45mm shiver | johall865 | Enduro Suspension | 0 | 12-28-2014 06:55 PM |
ec300 marzocchi 45mm | kingsizerizla | Enduro Suspension | 7 | 01-30-2014 10:51 AM |
Marzocchi 45mm bushes | iancp5 | Enduro Suspension | 0 | 02-25-2008 02:49 AM |
