#21
Before you venture too far,warm it up and check closely for coolant leaks,the front of the 't' is hard to see clearly.then partway into your ride check for leaks again.
After your first good ride its not a bad idea to recheck your head nuts and 't' torques either along with any other bolts you have removed along the way
2013 ec200r |
07 gasket kit into a 09? | lonetree | Enduro Engine - 2 stroke | 3 | 07-10-2014 12:14 PM |
Gasket Set. | Marki | Enduro Engine - 2 stroke | 3 | 12-02-2011 06:15 PM |
Exhaust gasket | Biff | Enduro Engine - 2 stroke | 1 | 05-28-2011 05:48 PM |
Ec 250. 2001 gasket | dareuk | Enduro Engine - 2 stroke | 2 | 04-22-2011 11:46 PM |
Base Gasket | gtsnowcrack | Enduro Engine - 2 stroke | 6 | 09-09-2006 05:43 AM |
