Old 02-01-2011, 01:53 AM
twowheels's Avatar
Default Wiring and Connectors from '11 eStart SwitchPod
I'm trying to work up a kit to utilize the stock 'mongo' switchpod in a street-legal package, but I don't have an eStart bike and the page from the manual on the web is unreadable, so ...
Can someone please post the e-start wiring diagram in a format that can be blown up and read OR
Post pictures of the innards of the switch pod, the nine-pin splice connector, and the jumper that heads to the headlight.
Many thanks
Steven Beane #275
afterhourscycle.com
Old 02-01-2011, 04:38 PM
Neil E. Neil E. is offline
Steve,
Here are the functions:
Red 12VDC feed goes to:
1) Engine Start Button (via a red/blue joined to the red inside the tubing jacket), out on black/white
2) Turn Signal Button (via a red/black wire joined to the red inside the tubing jacket), out via a separate connector with green (right signal) and brown (left signal)
3) Horn Button, out on grey
Green/Yellow wire chassis ground goes to:
1) Kill Switch Button (via a yellow/red joined to the green/yellow inside the tubing jacket), out on yellow/white
2) Headlight Switch board for LED indicator circuit
Yellow 12VAC feed goes to
1) Headlight switch common pole, out on white for low beam and blue for high beam
Note that the 9 pole connector has only eight wires installed.
I can take some pictures tomorrow.
2011 EC250E
Old 02-02-2011, 01:16 PM
Emailed the pics to your plus one performance email address so you get them full size. Let me know if you need a pinout.
The wiring diagram shown in the complete 2011 manual is a bit clearer than the one in the 2011 estart manual.
2011 EC250E
Exposed connectors pistol General Discussions & Announcements 7 01-28-2011 09:11 PM
New battery and option for estart forgiven Enduro Product Announcements 3 01-20-2011 08:26 PM
2005 to 2011 estart conversion forgiven Enduro Chassis & Body 1 01-17-2011 07:34 PM
A Shout out to eStart twowheels General Discussions & Announcements 5 04-19-2010 07:34 AM
Sealing Electrical Connectors iancp5 Enduro Electrical & Wiring 3 11-23-2007 09:58 AM
