Sag set-up
I'm getting around to setting up the suspension on my 05' EC300. I've seen/heard two schools of thought regarding the Sag measurements.
The first is take the meas. with the bike on the stand (suspension unloaded) and then take the meas. while on the bike in normal stance on the footpegs. Take the difference, etc. The second is to take the meas. with the bike upright but on the ground(suspension loaded) and then take the second meas. while on the bike in normal stance on the footpegs. Any advice out there?? thx/Mike '05 EC300 |
There is a measurement for static sag - just the bike weight and one for rider sag with you on it. When they and the preload are within bounds you have it setup correctly. For example and I'm making the numbers up because I can't remember. Static = 35 mm Rider = 105 mm Preload between 2-10mm Preload being the reduction in spring free length from the adjusting rings only with bike on a stand. |
Mike,
Check out LTRace's post on the FAQ suspension settings. He discusses the 2004-2006 rear shock preload settings.
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
