Old 12-28-2015, 11:24 AM
Russmann Russmann is offline
Default Marzocchi 45mm settings
Hello everyone.
I have the 45mm front forks. Can anyone confirm rebound and compression factory settings. Also. Compression top or bottom. I always had it as compression at the bottom. But some browsing says compression is at the top. Anyone got a link or a manual to assist.
Old 12-28-2015, 04:32 PM
rvangeel rvangeel is offline
The outer red nut on the top adjusts the preload of the fork spring. (Which is quite rare I think for front forks). Not sure about the dampening adjusters though.
Old 01-23-2016, 06:20 AM
stian stian is offline
Preload is on top, in the middle of the red nut. Its a golden flat screw.
Compression is in the bottom of the fork, often some rubber cap on it.
I think, more preload is turning it down, and more compression is turning the screw against the tripple-trees, meaning upwards.
Old 01-23-2016, 08:02 AM
Tbucket's Avatar
Tbucket Tbucket is offline
Top is REB @ 11 turns / clicks
Bottom is COMP @ 10 turns / clicks
All the turns are counterclockwise from closed
Per factory manual.
Is you send me your email to can send you a copy of the manual.
Old 01-24-2016, 02:44 AM
twowheels's Avatar
Well, no.
Preload adjustment is accomplished by turning the red nut. Turning it clockwise adds preload to the spring.
The screw in the center is rebound. Screwing it all the way in will have a similar effect to adding a lot of compression, but your rebound will also be very slow.
Compression adjustment in the bottom fork lug. Looking at the face of the screw (either by laying on your back or craning your head around), clockwise adds compression damping.
Steven Beane #275
afterhourscycle.com
Old 11-09-2016, 04:36 AM
HayNic13 HayNic13 is offline
Guys am I correct in saying that on the 2011 Marzocchi 45 Shiver forks as in the above pics the preload (red nut) has to be fully turned in anticlockwise?
My manual says this is the standard setting for these forks.
Old 02-10-2020, 10:33 AM
Dylonl Dylonl is offline
I realize this is a very old thread but it’s the only info I can find on these shocks?
I have same same problems as listed above. however, I cannot set the preload on my shocks. For some reason the flat head screw inside the big red adjuster does not reach a fully closed position, no matter how many time I turn it. I’m not sure if I’m doing something wrong or not. I’m very inexperienced with this topic. I’d really appreciate any help. Also, if anyone can help with the manual?
Old 06-01-2020, 09:01 AM
Down2fix Down2fix is offline
Originally Posted by Dylonl View Post
I realize this is a very old thread but it?s the only info I can find on these shocks?
I have same same problems as listed above. however, I cannot set the preload on my shocks. For some reason the flat head screw inside the big red adjuster does not reach a fully closed position, no matter how many time I turn it. I?m not sure if I?m doing something wrong or not. I?m very inexperienced with this topic. I?d really appreciate any help. Also, if anyone can help with the manual?
I had same issues with one of my rebound adjusters. So I removed that cap to inspect it. Well turns out that the screw head snapped off from the threaded adjustment part, (all self contained in the cap)
So start looking for a new fork tube cap.
2011 ec250 all the scorpion racing goodies, fmf gnarly, lector carb, fully setup for hare scrambles.
About the MArzocchi 48mm shims stack settings dsp Enduro Suspension 16 08-31-2018 08:26 PM
in need of some 45mm marzocchi shivers astout93v General Discussions & Announcements 0 06-23-2011 06:41 PM
Marzocchi 45mm bushes iancp5 Enduro Suspension 0 02-25-2008 02:49 AM
