Old 12-08-2011, 09:49 PM
Brian's Avatar
Brian Brian is offline
Originally Posted by fatdaddy View Post
got a 07 yz kickstarter and when i put it on my 07 ec300 it slides back and forth on the shaft. the splines dont go all the way through like on the GG one so the bolt just tightens up on the shaft but the starter will slide back and forth. Any of you all run into this
Yes I found the same thing. Effectively creates some slop, likely will destroy the shaft at some point. Oh well.
2006 Gas Gas EC250
2011 Husaberg FE390
Old 12-09-2011, 09:22 AM
Idahocharley Idahocharley is offline
If I had slop in a shaft due to a change in a kick start lever I would be looking to use a spacer on the shaft between the case and the lever to take out the slop. Many motorcycles use a spacer in this area. An "oh well" is likely $$$ down the road where a spacer made up even from a hardware store spacer stock ground/cut to the right length is maybe $2. Just my .02.
Old 12-09-2011, 11:04 PM
fatdaddy fatdaddy is offline
yea my buddie is a mill wright so we are going to make a spacer and also take the slack out of my brake by installing a bushing. One of my friends owns a moto recycling place and has a 250f kick starter on his yz 2T and he has a bunch of the 250fs but they have the same machined area on them. so is there a yz kickstarter that is splined the whole way through that needs no mods? I have had the bike for two weeks and have rode it 28 min and have lost multiple bolts broke gas cap and broke brake lever and never went down. I hope when i get it all fixed and go over bike it is more faithfull in the future.
Old 12-09-2011, 11:13 PM
PEB PEB is offline
I Use a stack of washers under the bolt to push it firmly onto the shaft.
Thread Tools
Display Modes
Kick Starter ? rockrider1 General Discussions & Announcements 1 11-04-2010 08:49 AM
07 250 Kick Starter prk03 Enduro Engine - 2 stroke 2 03-28-2009 10:59 PM
Kick starter? 2 strokes 4 life Enduro Engine - 2 stroke 2 09-08-2008 09:47 PM
Kick starter probs peterr Enduro Engine - 2 stroke 4 10-03-2007 05:36 AM
