Old 03-24-2019, 02:29 PM
Xitemntracing's Avatar
Xitemntracing Xitemntracing is offline
Default Noise in top end
I have an 18 gp 300 with a lectron and rk tech billet head. Bike is new with 100 miles on it. I get a intermittent clank from the top end when holding at 1/4 throttle. plug looks fine ,and bike has the update for the ecu from Gasgas. Head was milled for my elevation ,but is cold here. Have not tried mixing race gas yet , back to 2 strokes after many years on four stroke so need a little advice. Is this an octane problem ping ? timing out? It is freaking me out !
2018 300 GP
2006 yz 450f
Old 03-24-2019, 03:59 PM
frankinberg's Avatar
Is it a ping might need race gas or 50/50 pump gas with race gas get 100 octane min
Old 03-24-2019, 09:36 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Possibly rich at that particular throttle position? If so the noise could be unburnt fuel igniting in the exhaust/expansion chamber.
Try moving the carb needle up/down a clip position and see if it's better or worse.
Do you know what compression ratio you have? As Frankinberg suggests you may need higher octane race fuel to enable you to run a higher than stock compression ratio safely. If it's pinging/detonation don't ignore it or you could end up with a hole in your piston.
I used to race a Honda RS125 GP roadracer, it ran really well with 50/50 mix of Avgas and 98 octane pump fuel. This was recommended by Frank Wrathall, one of the UK's top race tuners. I used to get the Avgas from a local air field.
All the best, Dave.
Old 03-24-2019, 09:57 PM
has a lectron and plug looks fine not a pipe bang it is in the chamber. don't know compression ratio but will call rk tech in the morning. head was made for pump gas.....
2018 300 GP
2006 yz 450f
Old 03-24-2019, 10:29 PM
Davehuge's Avatar
Originally Posted by Xitemntracing View Post
has a lectron...
Oppps, sorry missed that!
Sounds like detonation then. Can you fit the stock cylinder head and try running it like that? Or try some High octane race fuel?
To get an accurate compression ratio measurement you'd have to give them your complete engine to measure, unless you're confident of measuring it yourself.
All the best, Dave.
BTW... There's a common misconception that High octane fuel gives more power which isn't true, it allows you to run higher compression ratio (which in turn gives more power) without premature ignition/detonation.
Old 03-24-2019, 10:36 PM
Thanks Dave I am getting some race gas this week to see if it solves it....
2018 300 GP
2006 yz 450f
Noise? 12Bravo Enduro Engine - 2 stroke 19 10-20-2015 06:55 AM
noise bkwdc Enduro Engine - 2 stroke 3 06-30-2013 11:38 PM
Noise after top end stabak Enduro Engine - 2 stroke 12 07-05-2012 10:32 AM
Top end noise ? Link Enduro Engine - 2 stroke 7 01-17-2008 03:33 PM
Bad Noise roostafish General Discussions & Announcements 17 01-10-2008 08:30 AM
