Old 11-11-2006, 07:06 PM
ScottyR ScottyR is offline
Junior Member
Default FSE 400 piston crossover?
I have a buddy who needs a piston for his 03 400FSE. We found out that the OEM piston is beyond crazy price-wise! Any truth to the rumour that a DRZ400 piston works?
Thanks
Old 11-14-2006, 10:16 PM
sn22 sn22 is offline
Ill check into this on Wednesday and let you know.
Old 11-16-2006, 05:35 PM
Hi, I have verified that this does work. You can checkout www.wiseco.com and they list a standard compression and a high compression for the DRZ. These are the same pistons as your 400.
Old 11-16-2006, 09:44 PM
Junior Member
Thanks bud! I really appreciate it!
Old 11-17-2006, 07:09 PM
jeffd jeffd is offline
I will add this to the parts crossover list when I get a chance.
As a follow on question - does anyone know if any of the valve-train components will interchange as well?
thanks,
Old 11-17-2006, 08:42 PM
Junior Member
I have been told that DRZ valves work better in the FSEs than the OE versions.
Old 03-06-2007, 04:12 PM
jib4pow jib4pow is offline
Default DRZ 400 piston work in GasGas?
Althought the piston's are the same size, is the connecting rod and everthing else located in the same place?
07 Ec 300 piston crossover wence Enduro Engine - 2 stroke 11 05-31-2010 04:36 PM
250 EC Piston pbspecial Enduro Engine - 2 stroke 6 05-11-2010 06:44 AM
Piston crossover? roostafish Enduro Engine - 2 stroke 10 04-13-2010 09:37 AM
Piston Kit for 99 Gas Gas 300 EC TorbenS40 General Discussions & Announcements 2 04-06-2010 05:44 AM
piston W8TSON Enduro Engine - 2 stroke 1 07-31-2009 12:25 PM
