Old 05-26-2019, 01:14 AM
(F5) (F5) is online now
Thanks mate I'm thinking of writing an antipodean manual for our bikes. Main tool 3lb hammer (must metricise that). . with a decent length of no.8
Here's what I'm drinking. Can says its exported over there. Do try find some. You wont be disappointed. 2 Kiwi and 2 Aussie Hops. Nice.
Been out riding today. Mint.
Old 05-26-2019, 01:26 AM
Pic didn't copy try again.
Old 05-26-2019, 03:11 AM
gg3's Avatar
gg3 gg3 is offline
F5,How about an NZ tool exchange site?
I have a phillips screwdriver that doubles as a punch & bearing extraction tool.
I heard of a guy in Auckland that has nearly a full socket set!Just missing the M8 & M12 & the ratchet only works one way.
Old 05-26-2019, 03:59 AM
You're drinking trans beer? f%!!5!!
Old 05-26-2019, 07:05 AM
shawbagga's Avatar
I call BS. It's always the 10mm socket that goes AWOL!
'18 Gasgas XC250
Old 05-26-2019, 01:55 PM
Oh gawd. Is it Monday already?
Old 05-27-2019, 04:56 AM
gg3's Avatar
gg3 gg3 is offline
They make 10mm sockets?
F5 is on to something,a trans beer gives us 4 more hours drinking time!
Old 06-01-2019, 03:20 AM
Well I've been on the Behemoth again , including a Transtasmin. Its spectacular. Then on to Marlborough savs. Just fantastic.
Drain bolts you say?
Old 06-01-2019, 03:38 AM
rodent's Avatar
rodent rodent is offline
Maybe a Dowty seal(bonded) the correct size would work?
Old 06-04-2019, 12:55 PM
opm22 opm22 is offline
Originally Posted by gasgasman View Post
I use part of the power valve cover gasket. Just cut around one of the bolt holes.
I use a very similar soft material. Just a little torque on the drain bolt and never leaked.
Coolant doesn?t drain from drain bolt? 2012 250 ec Si176 Enduro Other... 4 11-19-2017 11:03 PM
Coolant drain bolt Lonestar4x4 Enduro Engine - 2 stroke 7 05-24-2012 08:13 AM
oil drain bolt in case jyellard Enduro Engine - 2 stroke 11 10-13-2009 04:39 AM
oil drain bolt crossover ? Brian VT Enduro Engine - 2 stroke 6 08-04-2009 08:11 PM
water pump? nhrider Enduro Engine - 2 stroke 17 12-21-2008 12:05 AM
