Old 08-29-2018, 06:38 AM
ian1987 ian1987 is offline
Default Misfire
I have a 2008 EC300
It runs perfect low down and to about 3/4 throttle however just when you'd expect it to come into the power, it goes flat and starts to splutter.
The bike previously ran perfect to full power so I know jetting isn't the issue. I've cleaned all carb jets and put in a new plug
Bike is run at 50:1 with good quality oil
Im beginning to think the power valve isn't operating properly. Anyone have any ideas?
Old 08-29-2018, 07:02 AM
Anders Anders is offline
Originally Posted by ian1987 View Post
I have a 2008 EC300
Take off the RH power valve cover and have a look. Perhaps the actuator arm is broken. Start the engine. It will make a lot of noise, but it will run. See if the arm moves up and down as expected.
Old 08-29-2018, 07:28 AM
Yes check the power valve.
Old 08-29-2018, 07:40 AM
pscook's Avatar
pscook pscook is offline
Also check to see if your silencer/spark arrestor is plugged. The packing can get soaked with oil and collapse, thereby restricting the exhaust.
Phil
(New bike pending...)
Old 08-29-2018, 08:11 AM
There seems to be a fair bit of oil around the end of the silencer, I will repack
The power valves seems to be properly intact
Old 08-30-2018, 03:51 AM
RBrider's Avatar
RBrider RBrider is offline
Have you checked for a blocked air filter? Beads of water in float bowl?
RB
FSE 450 2005 idle misfire/stall when hot Tafka Enduro Engine 4 stroke (including EFI & Exhaust) 57 04-12-2022 10:11 AM
