Old 09-16-2021, 02:48 PM
tholt2 tholt2 is offline
Default 2011 Txt Pro 250 Clutch Bolts
How do I remove the star bolts? 8mm socket is too big and 7mm is too small
Is there a special tool?
Also how do you remove the basket? I've taken the breather bolt out but it still feels locked into place
Thanks
Old 09-16-2021, 04:47 PM
Gasser Nate's Avatar
Thanks
Are you using a 7mm double hex socket? They look identical to the ones I just removed with that. And yes it is the small 5mm hollow Allen key in the centre of the clutch to remove it. It may just need some gentle leverage.
Old 09-16-2021, 04:48 PM
swazi_matt swazi_matt is online now
that looks like a job for vice grips and a trip to the bolt shop
2003 txt250 Pro
2013 Ossa 280i
Old 09-16-2021, 10:54 PM
Only the genuine ones have a small enough head to not get hit by the clutch cover. Unless you use button head Allen bolts which always round out.
I got by with a 7mm ring spanner, they are only done up to something small like 6/7nm
Old 10-10-2021, 12:11 PM
Well good news is the 7mm ring spanner worked on all but one.
Bad news is one was already partially rounded and the ring spanner is not gripping. Any ideas?
Thanks
Old 10-10-2021, 06:22 PM
Neil E. Neil E. is offline
Hacksaw or dremel a screw driver slot in it, then get a replacement bolt.
2011 EC250E
Old 10-10-2021, 07:56 PM
And do the bolts up around it to take some load off it. It will come out easier.
Thread Tools
Display Modes
clutch/brake bolts 2smokin Enduro Chassis & Body 0 09-19-2019 07:51 AM
Clutch cover bolts on 2011 bikes GasGas General Discussions & Announcements 4 05-02-2011 08:20 PM
Removing stock handguards & lever bolts 2011 epirtle Enduro Chassis & Body 0 02-26-2011 12:57 PM
Clutch / Brake Banjo Bolts iancp5 Enduro Chassis & Body 2 11-24-2009 04:14 AM
