08 top shock mount.
I've found mine has some play in it, is this normal on a 14 month old bike?
Has anyone had a simular problem? if so whats the repair. I've not taken anything apart yet, just want to know what i'm getting into really. |
Hello, anyone?
Where is the movement coming from ? The bearing itself or is the bolt not really tight. I found you had to tighten the top bolt a fair bit.
"It's Nature that Brings out the Madness" GasGas FSR450 07' |
I'll check the bolt, but i'm fairly sure it's the joint.
Are the joints unbustable? |
Bottom Shock Mount | PEB | Enduro Suspension | 6 | 10-12-2007 04:13 PM |
Upper shock mount | PEB | Enduro Suspension | 1 | 10-02-2007 11:51 AM |
Upper shock mount | PEB | Enduro Chassis & Body | 1 | 09-14-2007 02:33 PM |
Top shock bushing/mount 07 ohlins | highspeedsteel | Enduro Suspension | 13 | 07-24-2007 07:53 AM |
