Old 02-27-2017, 04:03 PM
Harry's Avatar
Harry Harry is offline
Wink
HI Bob,
It looks the same as my bike, which is a 2002 EC300.
I am happy with the following jetting at 500m elevation and 10-25 deg.C temp.
pilot- 40
needle- N3EG clip 2 or 3 from the top (Yamaha / Ktm needle)
main - 178 / 175
slide -7
Like all bikes it will take some time and effort to set it up to your needs.
Old 03-01-2017, 03:34 AM
stay_upright's Avatar
stay_upright stay_upright is offline
On my 05 300 what I found to reduce the 4 stroking was a #9 slide with a 35 pilot. The pilot on its own was not enough as it only adjusts a certain range. The #9 slide is whats fitted for hollmologation (at least in the uk) so dealers have them and i got mine free as they fit the 'racing' #7 slide when new and normally chuck the #9 in the bin. It may also be worth noting if your needle valve is worn you may need a needle with much bigger diameter shaft to compensate and get the jetting near correct.
Sent from my EVA-L09 using Tapatalk
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 03-02-2017, 08:29 AM
risk74 risk74 is offline
A few answers to your post:
1. "I'm new to two-strokes. And I probably should have bought a different bike"
That's obvious if you think that thing is ever going to run right without the airbox side cover on. And yes, you should have bought a different bike.
2. Another thing is the air box. I don't really see anywhere where the freaking air is supposed to go in.
The airbox works exactly like it is designed to. If the bike does not run properly, there is another problem somewhere. You are not smarter than the engineers that designed the airbox, re-engineering it is not a solution.
3. Wit pissed fuel on the sidestand, which I removed. What a freaking joke.
So instead of fixing the fuel leak problem, you removed the sidestand? Yes, that does sound like a joke.
4. esoteric crap just to ride to grandmas house once in a while. This is not an enduro... it's a motocross bike with plates,
You sir, could not be more wrong. I ride and race more woods hours in a month on a 2004 Gas Gas EC300 than you ride in a year, have won races with said bike against modern machines. The thing is dead nuts reliable (as reliable as my KDX200). You have obviously inherited someone else's poorly maintained pile. The greatest machine in the world is only as good as the owner who takes care of it. If you decide to save it, (which I imagine you will not) it might just cost more money than it is worth to bring back into stock, reasonable mechanical condition. This is not due to the "esoteric" nature of the machine, but ham-fisted mechanics who have no clue what they are doing.
Good luck.
Kris Larrivee
Old 03-02-2017, 02:41 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
The air comes into the air box through the "handholds" cutouts in the side number plates.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Thread Tools
Display Modes
Is that normal??(video) adriano.ro Enduro Engine - 2 stroke 14 03-19-2016 03:01 PM
Is this normal gnilrub Enduro Engine - 2 stroke 17 02-09-2015 04:23 AM
Is 202psi normal? noobi Enduro Engine - 2 stroke 4 01-28-2011 03:01 AM
07' 300 overheating...I think(4 stroking, and coolant on engine)? CDBiker220 Enduro Engine - 2 stroke 14 11-22-2010 10:22 AM
Normal 08' 250? nick790 Enduro Intake/Carburetion - 2 stroke 6 03-25-2009 04:02 PM
