Old 07-06-2019, 08:16 AM
Dan Dan is offline
Default 2013 ec250 clutch master cylinder
Can anybody help me with what clutch master cylinder I may be able to swap/upgrade to on my bike. It currently has an ajp one fitted that is coming to the end of its life I feel so looking for some ideas on what to replace it with.
Thanks
Old 07-07-2019, 08:03 AM
Pygmygod Pygmygod is offline
Why end of life?
Is it leaking or dented or rusting internally?
You may be able to put a master cylinder seal kit through it and it'll be fine again with some new fluid.
Something like this:
https://ttmoto.com.au/shop/ajp-clutc...ral-oil-9-5mm/
(Check for the right one, I just did a quick google and came up with the above result)
Old 07-07-2019, 09:55 AM
Dan Dan is offline
Originally Posted by Pygmygod View Post
Why end of life?
Bike shop fitted a new seal kit and it?s leaking after one ride
Obviously I took it back to be redone and he has said that the bore looks worn and that?s why it?s leaking so will probably leak again after this new seal
Old 07-07-2019, 11:53 AM
Anders's Avatar
Anders Anders is offline
Thanks
You can look for a Magura. They were used in some models earlier than 2013 (e.g 2011 I believe). I think perhaps they are also used on the current models?
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 07-07-2019, 12:39 PM
cbutler's Avatar
cbutler cbutler is online now
Im calling BS on that. I have an 01 ec 200 that I have done nothing to. I have owned it for more than five years and ride about 200 hours yearly.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 07-07-2019, 02:21 PM
(F5)'s Avatar
(F5) (F5) is online now
Like brake masters, they are only bored into bare ally. They will eventually wear the bore. Some casting may be softer or slightly porous.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 07-07-2019, 04:11 PM
gasgasman's Avatar
The AJP master cylinders from that era have been of very low quality.
A Magura replacement will be a much better option.
Old 07-09-2019, 02:41 PM
Dan Dan is offline
Thanks all. I will have a look for a Magura that would fit then in case it starts to leak again.
2011 EC250 Clutch Master Cylinder Rebuild Kit sneaky98gt Enduro Chassis & Body 1 01-18-2018 08:02 PM
2013 XC300 clutch master cylinder. AJP or Magura? FastFast Enduro Chassis & Body 3 02-10-2017 01:51 PM
WTB clutch master cylinder 2001 ec250 lynngarner "Wanted to Buy" & "Want To Trade" 0 06-02-2016 05:33 PM
Clutch Master Cylinder Cory C Enduro Chassis & Body 2 05-03-2016 03:24 PM
Clutch master cylinder - 03 EC250 Roosta Enduro Chassis & Body 5 04-26-2014 08:57 AM
