Old 04-03-2013, 03:23 AM
andyec300r andyec300r is offline
Default 2009 ec300r sachs fork oil level/
So I've removed about 330-340ml from my 48mm Sachs cartridge forks when I replaced the seals. Now I didn't measure the oil height before I emptied them but was told by the previous owner that 120mm was the air gap.
The thing is I had to put 600ml in to achieve an air gap of 120mm! Is this normal? (measured air gap with spring removed and fork collapsed)
(The fork was blowing through the end of the stroke before)
Old 04-03-2013, 05:20 AM
Who knows how the previous owner did it? Usually 500-600ml of oil is right for 48mm OC legs depending on brand and oil height. For the Sachs I think spec is between 90 and 135mm (from memory only). Thats with springs out, fork collapsed. Maybe the previous owner didn't bleed them and just poured oil in to the right level and did them up?
Old 04-03-2013, 05:48 AM
n_green n_green is offline
Sounds close to me.
With 120mm air gap in my Sachs 48mm forks I use just over 1l of fork oil. Which is a pain because they sell it in 1l bottles...
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 04-03-2013, 10:59 AM
IDAHOSPUD IDAHOSPUD is offline
I would call Les at LTR
Old 04-04-2013, 05:08 AM
Thanks for that info, can't wait to see how it handles
2009 ec300r fork andyec300r Enduro Suspension 8 04-21-2014 06:12 PM
2009 EC300R 48mm Sachs Fork Seals andyec300r Enduro Suspension 4 03-18-2013 10:19 AM
2009 sachs fork lower pinch bolt Diggs345 Enduro Suspension 2 05-21-2012 01:22 PM
Keihin PWK 2009 float level 300ec Enduro Intake/Carburetion - 2 stroke 5 12-23-2011 04:22 AM
EC300R and the 2009 Dirt Rider Torture Test. Berkyboy Ride Reports 9 02-08-2009 12:36 PM
