2015 Silencer Mod Help Needed
I have read about guys cutting there FMF Silencer and when I look at mine it is HUGE ! So I am going to cut a bit off and wanted to hear what your results have been . Sound does it get a lot louder ? Less sponge , running cleaner / better ? Looks that will get better . Up high weight I am considering going down at least 4 inchs around 10 cm . I will rejet as needed since the stock jetting is off anyway . Thanks for your help !
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES |
Ever think about just buying a House of Horsepower silencer? Then you can keep your stock silencer in OEM condition for events that require a spark arrestor. They are much shorter and lighter and give a nice power boost.
That was the link I was looking for , thanks . I do not think there is a spark arrester on this silencer ? I do ride mostly in the woods that can be real dry at times so maybe I should put a silencer with a s/a on it . There was a 400 acre forest fire this weekend in our area SO maybe a s/a silencer is in order ?
No s/a on the '15 bikes.
Just a Powercore 2. |
Cut n Ready to jet , I believe there may be a spark arrestor made for this silencer . Otherwise I will have to get a silencer with a s/a just looking forward to how this one will sound and run .
The Q Stealth is the same size as the Powercore, just 2" longer.
I contacted ProMotoBillet to see if they had a s/a end cap that would fit, they said no. |
I cut 4 inches. Nothing remarkable to report.
Bud racing carbon-fiber silencer makes a big improvement.
2015 300 | celler | Ride Reports | 0 | 04-17-2015 10:57 PM |
2015 GG 300 video | gasgasman | Pictures & Videos | 7 | 01-21-2015 01:36 AM |
2015 otd | iamovru | General Discussions & Announcements | 10 | 12-21-2014 07:18 PM |
2014 vs 2015 300 | mgrumke | General Discussions & Announcements | 17 | 12-16-2014 10:31 AM |
