Old 05-21-2013, 09:16 PM
binsel binsel is offline
Default 2010 EC300 or not?
Hi All,
I'm 6'2" with longer legs and been riding 2010 EC300 I bought brand-new.
Recently, I rode 250xc-w and 300xc-w and wondered why I am not getting a similar power KTMs provide. They rev and provide great power, but mine does not rev as good and when I rev, it gives me vibrations more than power. On my bike, lifting the front requires decent amount of throttle on 1st gear. On 300xc-w 2nd, 3rd gear wheelies are easy.
I always get sludge regardles of premix ratio and the brand of oil I use.
So I am interested in APT's SmartCarb. I expect it will resolve the above issues.
Having long legs, I have to lift my whole leg for rear brake. On tight single-track I usually keep my right leg lifted whole time. It gets tiring and I get cramps after 2 hrs. The solutions is auto-clutch + LeftHandRearBrake. Unfortunately, Rekluse produces only the most expensive ($950) version of their auto-clutches for my bike while I need the basic one.
Plus, I prefer PDS or linkless shock over linkage due to less maintenance. All the bolt and nuts around linkage is very tight on my bike.
I love the handling of my bike but I hasitate to spend more money because of jetting issues and ergonomics. I assume it's a good chance I can find used rekluse or tall seats for KTMs.
Should I go to the orange side?
Cheers,
Burhan
Old 05-21-2013, 09:24 PM
bkwdc's Avatar
bkwdc bkwdc is offline
Default ktm
Yes. You should buy a ktm.
PS
I will buy your GASGAS.
I'm just sayin.
2011 EC300 Six Days
2010 EC300 Nambotin Replica
Old 05-21-2013, 10:12 PM
So what have you done/addressed on your Gasser so far? Has it always felt soft or just recently? How many hours?
Stock the bikes run overly rich if it has an AS2 carb with the N1EF needle.
A certain number of people have found considerably slop in the powervalve tension. Results in a soft bottom end.
Engine vibration - check engine mounts - but the 300 by nature will vibe a bit. The factory started installing sealed main bearings in 2010 which I think may increase the vibes once the grease starts to dispearse. I went to a 250 jug on mine and reduced the vibes alot. Then had the crank trued and new bearings throughout cases and it feels silky smooth. This was over 8000kms/260hrs though.
PS. It should easily lift the front in the bottom 3 gears. Mine will lift in 5th in the mid-upper rpm with nothing more than a tug at the bars and a crack of the throttle. It also sounds like you want a ktm..
Jetting and PV checks won't cost you much at all.
Old 05-21-2013, 10:15 PM
fletchman45 fletchman45 is offline
If your 300 will not wheelie easily in 3rd and 4th gear. THERE IS A PROBLEM!!! Yes the PDS has less maintenance however it takes a good suspension tuner to get it dialed and even then at least to me will not provide the ride quality of a good tuned linkage rear. I really do not like orange much. In the long run the Gas Gas should be a better bike and for sure cost LESS to maintain. You may be a little on the tall side for the old chassis (prior to 12 Gasser) but they do have tall seat options and handlebar riser options. I am only 5 foot 7 and rode a 11 six day 250 and a 12 300 back to back several times this weekend and must say for me the 12 and up chassis is VASTLY superior in ergonomics and handles sweet and will reward a fast rider who pushes it. For a taller guy the (and even a short guy like me) you may prefer a 12 or up gasser. My 300 engine pulls sweetly and wheelies (WHENEVER I WANT!) and revs out nicely!! Vibes a tish more then a 250 Gasser but rewords you with excellent bottom end grunt!!! So I guess, get your bike running right. (My god come on jetting is not rocket science!!) Work the height deal out Tall Seat and bars!!) Or grab a low hour 12 or new 13!! Gas Gas!!! But no I would leave the Orange for the KoolAid club!! Just saying...............
Old 05-21-2013, 10:33 PM
Cberg Cberg is offline
I'm just over 6' tall with long legs and ride a 2011 EC 300 and I am very comfortable on the chassis. I have never tried a 12 or 13 but would sure like too!!
When I first got mine it took me awhile to sort the jetting out and it never had the power I thought it should have either. Now that it is jetted properly it runs awesome!! Strong power throughout and just last week I took out the slop in the power valve and HOLY SH!$&":;!!!! It now flat out rips!!!
I would say spend a bit of time to get it dialed in and I think you will be very happy with how the motor will perform!
Old 05-22-2013, 07:51 AM
ScottyR ScottyR is offline
Junior Member
Originally Posted by binsel View Post
Hi All,
Cheers,
Burhan
Something isn't right. I have owned all of those bikes and a 300 GG has as much jam as a 300 KTM for sure.
If you want to spend some money, a lot of local guys have been putting Lectron carbs on their GGs with great success. Call Rob Lang. He stocks them.
I might have a line on a used Rekluse as well.
Old 05-22-2013, 09:47 AM
Coop's Avatar
Coop Coop is offline
That's pretty much a requirement unless you want parts falling off your bike. You will find the PDS shock bolts equally as tight.
I have a 2010 250 and have no trouble lifting the front end over logs, ditches, etc., even in 3rd. I weigh ~210#. Something is amiss with your bike.
GUTS Racing does makes a tall seat foam for our year.
I think you just want a KTM and are trying to justify it. KTM's are great, but they too have their own quirks. No bike is perfect, they all require personal set-up.
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Old 05-22-2013, 10:01 AM
Neil E. Neil E. is offline
Burhan,
Your jetting is probably too rich since you haven't changed the stock jetting. Switching to the Lectron would cost less than the smart carb and be all you need. Rob has them in stock. I doubt a KTM 300 would vibrate less than the GG.
You might want different pegs. I reversed a set of pivot pegs. This lowered the pegs and moved them back a bit. I found this made the bike more comfortable. A tall seat would help you.
I use mostly front brake when I'm riding and just stab the back brake for a few seconds to adjust my speed before a corner. Maybe one of those expensive Clake controls would be useful (combined clutch/rear brake).
I hear you on the linkage. It is a chore to service, but not that bad once you are used to the procedure. Since you are considering spending money on a KTM, you should talk to Rob and see if he can get you a test ride on a 13 GG that he set up. The pricing is probably pretty close.
Neil
2011 EC250E
Old 05-22-2013, 11:26 AM
Junior Member
After riding a 2013 GG 300 and a 2013 KTM 250XCW (PDS) back to back last weekend, I can 100% tell you that the suspension on the GG is better than the KTM.
Old 05-22-2013, 06:17 PM
Jakobi, it has over 100hrs and still has the same compression amount. It has always been the same since day one, and I have not done anything on the power/jetting side. I know 2 other riders who has the same bike, who has more experience on jetting. They played with jetting and came back to stock setting, so I did not touch it. I know one other who used YZ main, got the revs but lost some bottom.
Somebody told me to check for squish band clearance. It might be on the loose side (close to 2mm). I was told the ideal squish height is between 1.14 mm to 1.27 mm. The benefits of tighter squish are crisper power delivery, better and cleaner fuel burn, easiness in getting one's jetting right, and elimination of detonation!!!
For Power Valve adjustment, I guess I need different springs, right?
Thanks,
Burhan
2010 ec300 BryanMcc Used Bikes 14 04-17-2013 01:48 AM
Street kit for 2010 EC300?? GGCanuck Enduro Electrical & Wiring 7 04-09-2012 08:37 PM
Considering a 2010 GG EC300 Bailey28 General Discussions & Announcements 17 02-01-2011 07:05 AM
2010 EC300 Top Speed? binsel General Discussions & Announcements 19 01-29-2011 03:04 AM
