I pulled my seat for the first time today and am curious about a couple of things.
1. The giant hole that the water sits in where the top of the tank is secured to the frame.....What are your remedies for this
2. The seat only has one bolt at the rear from the factory, but is setup for two(one either side). It's a Catch22 situation fitting both bolts as the RH side cover requires that you remove the seat to undo it, which is ok if you have the factory fitted "one bolt"
But if you want 2 bolts in the seat you have a dilemma
3. The RH side cover has 2 access holes so you can remove the muffler, how often are you gonna be doing that?
Why couldn't Gasgas delete those holes and have one to access the RH side bolt for the seat? And if you need to remove the muffler you have to remove the side cover. Surely you will be removing the seat a shit ton more than the muffler??
