Front Sproket
I have read a lot about rear sprockets, but can't seem to find anything on the front.
What brands do you all use and where do you get them? 99 EC200 is the bike. I have a 12/48 gearing now. Looking to go with a 13 on the front and leave the 48 on rear and go from there. Front is cheaper than rear, so seems like a good start.
"There is no room in life for Regret, it's a useless feeling that leads to a negative attitude" I would rather call it the "Stupid Tax"! |
GG only, no interchange. Check ebay or the forum supporters. They're cheap.
Sorry, I thought you meant interchanges. Being steel the fronts last a long time pretty much whatever brand, just my opinion. Pretty sure 13t front was stock. I run 13/50 and my kid runs 12/49 if it matters.
I bought a Renthal 12 tooth a couple years ago through GoFaster's. My local bike shops' catalogs did not list the application so I'm not sure how easy it is to get on the local level. My factory 13 tooth was made by Talon if I remember correctly.
JT makes steel sprockets for the front.
Dick Carnes "If ya run, you'll only die tired" 2019 EC 300 2018 GP 300 2013 XC 300 (sold) 2006 DE 300 (buddy has it) |
Thanks...
I just found a JT 13T on Amazon for $17 that is Prime available! Heck yea! Just ordered it.....
Yep, that's where i get em. Don't buy the JT chains
What chain do you recommend?
I have Used DID O or X ring chains with good results for many years. The X ring type has somewhat lower rolling friction.
Sent fra min GT-I9295 via Tapatalk
I used Regina ORN6 chains right up until they sold out to MSR. Always got wear on the sides so I went with the narrow DID X-Ring. No more wear on the sides and seems to be holding up.
Ditto - lasts as long as the highest priced chains but can be purchased much cheaper. I usually get short ones on fleabay and join them together.
Thread Tools | |
Display Modes | |
WTB New front rim | john r b | "Wanted to Buy" & "Want To Trade" | 6 | 11-29-2014 08:06 AM |
FOR SALE, 250XC forks, NEW fender, front wheel, front wheel bearings | iamyvr | Parts | 5 | 07-27-2014 08:18 AM |
14 front sproket | gg3 | Enduro Chassis & Body | 13 | 09-26-2010 12:19 AM |
countershart sproket spoogle... | Alex401Smith | Enduro Engine - 2 stroke | 1 | 08-28-2007 08:45 AM |
