Old 03-21-2018, 10:24 AM
poelinca's Avatar
poelinca poelinca is offline
Default Rear brake pedal bearings and bushings crossover ?
Are there any crossover bearings, bushings, seals and washers for the rear brake pedal ?
Mine are broken, literally split a bearing apart, the seeger washer and bushings on that side can't be reused anymore. I'm looking at the whole "kit" so to speak, 32 thru 35 in the pic bellow
I could order from Spain as I usually do, however I do have everything else I need for the spring clean-up so I'm looking to save on shipping costs.
'14 EC300
Old 03-22-2018, 01:07 AM
Gasser Nate's Avatar
The bearings can be bought from a local bearing place easy as. The other stuff might have to be machined up on a lathe if you need them in a hurry.
Old 03-22-2018, 07:24 AM
poelinca's Avatar
Taught so, I ended up placing the order from Spain. I'm not close enough to a shop that can machine the bushings.
Thanks,
Dorin
'14 EC300
Old 03-22-2018, 01:22 PM
(F5)'s Avatar
(F5) (F5) is offline
My arrangement were a bit worn so I used a push in slide bush and machined a piece a bit larger to be a better fit ti the frame hole that was a bit flogged out.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Rear brake pedal crossover? jt633 Enduro Chassis & Body 14 09-14-2017 09:20 AM
Brake Pedal crossover SwampGasser Enduro Chassis & Body 2 01-31-2017 06:44 PM
Ec300 2012 rear brake pedal bearings etc info MYBOARDSNOTFLAT Enduro Chassis & Body 2 05-12-2015 04:47 AM
kx brake pedal crossover dan586 Enduro Chassis & Body 4 09-22-2014 05:12 PM
parts crossover - rear brake pedal? stainlesscycle Enduro Chassis & Body 8 06-16-2011 07:05 PM
