Old 05-03-2019, 07:41 PM
David_viny David_viny is offline
Question Air box pictures requested!
New owner of a 2005 Gasgas EC250 converted to 07-11 plastics & airbox etc. ( I think?)
Unfortunately the previous owner I believe has used all the wrong bolts for the airbox to air boot connection leaving it warped and i'm sure has air gaps.
If anyone has pictures of there 07-11 air box to boot connection I would really appreciate it!
Here is a picture of what I currently am working with:
https://ibb.co/mhP2nt7
https://ibb.co/ZV27v6J
https://ibb.co/MSd0YrN
https://ibb.co/rw2NKYT
Old 05-04-2019, 02:41 AM
They don't typically use bolts on the new ones at all. It's a double lip.. Think of a grommet. One side sits in the airbox and the filter seals against it. The other holds the air intake/boot in the void in the airbox. Even though it can move around etc it's entirely sealed internally.
Old 05-04-2019, 05:14 AM
Davehuge's Avatar
Davehuge Davehuge is offline
You can download the official manuals with exploded views and parts lists from the official GasGas website, I guess they may help you.
https://gasgas.com/en/manuals
All the best, Dave.
Old 05-04-2019, 11:23 PM
I've seen the manual before, I guess I'm not totally seeing how its supposed to go together. The metal ring looks like it has holes in it for bolts??
Old 05-05-2019, 12:35 AM
The metal ring isn?t used on those models. Only for the early ones. The later models use a spring loaded pin to hold the filter in place against the air boot.
Old 05-06-2019, 06:55 PM
I have a spare air boot here that I can take a photo of if it helps you visualise.
Old 05-06-2019, 07:25 PM
rvangeel rvangeel is offline
Default Air box pictures requested!
Here is a picture of a 2005 with the 2011 update kit. The air boot has a double lip that goes on each side of the air box so the seal between the two isn’t critical. (The air filter seals to the air boot directly)
Old 05-06-2019, 07:32 PM
Here is a picture of the inside
Pictures Upyourkiltbatman General Discussions & Announcements 2 02-05-2015 04:08 PM
How to post pictures ? Dirt Dud General Discussions & Announcements 5 10-09-2014 08:43 PM
Pictures from VA National Rod Overstreet Pictures & Videos 8 07-17-2014 01:53 PM
Lot of parts see pictures Jiikoo811 Parts 6 01-15-2014 05:09 PM
Where are the members Pictures ???? Kell General Discussions & Announcements 5 09-14-2011 08:46 AM
