Old 01-25-2016, 06:34 PM
HooliKen HooliKen is offline
Default 2006 EC 200 Cylinder head Issue???
Doing a pretty thorough refresh of my recently acquired EC 200. Cylinder head was not looking healthy, so I ordered a replacement from Motocross Center. Ordered part ME200216000, which according to parts list is correct. New head showed up today and low and behold it is quite a bit smaller than the one that is currently installed. Current head is marked with ME25-30916000, which turns up nothing in parts list or google search. Anybody offer an assistance? Part number is similar to the 250 head, but not an exact match. Any help is greatly appreciated.
Old on right. New on left.
Thanks Ken
Old 01-25-2016, 06:53 PM
Zman's Avatar
Zman Zman is offline
I just checked the number on a 2004/2005 200 head and it matches your new one MI 1600000.
Your head seems to be a 250 head. http://www.gasgasrider.org/forum/showthread.php?t=2112
You may have a 250 engine in your bike. The 250 is a direct swap for the 200.
Old 01-25-2016, 10:02 PM
Tbucket's Avatar
Tbucket Tbucket is offline
Looks like you have a 250 or 300 not a 200
Measure the piston. That will Tell the size
200 is 62.5 mm
250 is 66 mm
300 is 72 mm
Old 01-26-2016, 01:47 AM
(F5)'s Avatar
(F5) (F5) is offline
What does, not looking healthy mean?
Evidence of debris damage?
As it happens machining the head for the right squish and shape removes quite a bit of metal so could repair most not crazy violent damage.
RBor suitable tuner could perform or assess.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 01-26-2016, 03:43 AM
Spark plug threaded hole is wallowed out a little. Checked with a couple of local machine shops that "maybe" could fix it. But they are not really into doing Moto stuff. Got a pretty decent deal on a new one but alas, she does not fit. Sent the part number on the existing head to MX Center to see if they can help me out. Relatively new to Gas Gas and still learning the ins and out.
Thanks
Ken
Old 01-26-2016, 10:37 AM
Neil E. Neil E. is offline
I would probably repair the spark plug thread with a helicoil if all else on the head is good.
2011 EC250E
Old 01-26-2016, 12:32 PM
Rick's Avatar
Rick Rick is offline
^^^^^ This is the direction I would go as well.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 01-26-2016, 04:12 PM
Thought about that. I am guessing you can get a threadsert or guardsert that would work.
Sent pics of the difference in size to MX Center.
Anybody has a 200 head laying around to get some dimensions? Diameter and bolthole to bolthole?
Old 01-26-2016, 05:59 PM
pscook's Avatar
pscook pscook is offline
Measure the protruding lip (the part that sticks into the cylinder) on both heads and compare. The 200 has a 62.5mm diameter, the 250 has a 66, and the 300 has a 72 (IIRC).
Phil
(New bike pending...)
Old 01-26-2016, 06:02 PM
cbutler's Avatar
cbutler cbutler is offline
What is stamped on the side of the motor in front of the shiftier? As stated you may have a 250/300 motor in it or someone mite have put a 250/300 top end on the 200 bottom. Get the calipers out.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Swopping 1997 Cylinder head with 2005 head EC250 Enduro Engine - 2 stroke 10 12-15-2015 10:13 AM
Coolant leaking through cylinder head socket-head bolts. GGRider01 Enduro Engine - 2 stroke 5 10-17-2015 07:38 PM
Issue with Clutch Master Cylinder 95jersey Enduro Chassis & Body 10 05-24-2015 12:47 PM
250 Cylinder Head mcnut Parts 2 04-13-2015 06:30 AM
New cylinder head Kent A Enduro Engine - 2 stroke 8 05-01-2007 01:43 PM
