Old 03-08-2017, 09:08 PM
philm philm is offline
Originally Posted by pscook View Post
Thanks for the pictures, guys, and sorry to thread jack. I have the tail light support on my bike, but it's coming off soon for an upcoming race (Desert 100!). I see how you both have it mounted, and that makes great sense. I will likely do the same if you both agree that it's strong enough back there with those little 5mm bolts. Better than using the airbox holes/handles, I bet.
Not sure what size the bolts are exactly but their website shows that they supply M6 and M8 bolts. Either way they are plenty strong enough for lifting the rear of the bike.
Old 03-09-2017, 04:16 PM
Martin-EC300's Avatar
Martin-EC300 Martin-EC300 is offline
Mines an 08 with '12 front plastics, haven't found the need to update sides or rear yet
Old 03-27-2017, 05:50 PM
Jim_C Jim_C is offline
Martin-EC300 Your radiator shrouds are pointing the wrong direction mate. The white shrouds in front of the radiators should be pointing out from the middle of the frame for max air flow. You could overheat your steed... Nice EC300 by the way.
Old 03-27-2017, 08:22 PM
dANbOT's Avatar
dANbOT dANbOT is offline
I already posted these on my own thread, but what the hell... I'm pretty stoked about how it turned out!
2014 with a 2017 kit installed. came with everything except the steel clips that join the 2 halves of the rad shrouds. I did not install the open hand guards or the swing arm decals, I think it looks better black.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 03-29-2017, 06:48 AM
Zrt1200 Zrt1200 is offline
Here is a before & after. I did this last fall when I was done riding for the year. Its a 05 Ec200 with the Motocrosscenter special mod kit.
Old 03-29-2017, 06:56 AM
Yngvim Yngvim is offline
Great job, looks good
EC 250 2001, FSE 450 2004
Old 03-29-2017, 08:40 PM
eff's Avatar
eff eff is offline
Makes me want to do my 2004. Nice work
Sent from my Pixel using Tapatalk
2004 GasGas DE250
Old 04-09-2017, 04:07 AM
Gleiwitz Gleiwitz is offline
I need your help with trannsformation kit. I would like to assemble it well so I have some questions about air box.
Below the air box 2005
So I noted that in 2011, no part of the number 3 and 6 (form 2005 manual), this metal pieces.
How exactly is it assembled in 2011?
Should I install these old metal parts from 2005 and drill holes?
I will be grateful help or some photo of air box
Gas Gas EC 300 2005
Suzuki RMZ 250 2004
Husqvarna WR 360 1996
Old 04-12-2017, 12:35 PM
I installed the air filter according to the 2011 diagram.
I'm not convinced of the tightness of this solution. How is it done in the original? Is air filter rubber sealed with silicone?
I still have the impression that this older solution was stronger and certainly tighter.
Can any of you tell me how it is factory-assembled?
Gas Gas EC 300 2005
Suzuki RMZ 250 2004
Old 04-12-2017, 01:44 PM
pscook's Avatar
pscook pscook is offline
That looks just like the way the filter on my 2011 looks. If the pins in the cage are not lined up with the opening, the spring loaded holder won't fit. It is very solid. I make sure that I have a clean surface and then I try to rotate the filter and feel around it to make sure it is sealed against the air boot.
Phil
(New bike pending...)
Will the newer model plastic fit older bikes? juice76 General Discussions & Announcements 9 10-14-2020 03:44 PM
new body work on older bike? knobbyboy Enduro Chassis & Body 18 01-12-2011 05:40 PM
Older GasGas Questions nick2510 General Discussions & Announcements 10 12-16-2010 07:03 PM
Vancouver Bike Show HuskyDude General Discussions & Announcements 8 01-26-2010 10:14 PM
