Old 06-07-2016, 02:29 PM
Tiddlesrx7 Tiddlesrx7 is offline
Default How much fork oil?
Can anyone point me in the right direction so I can find what oil level I need for my forks? The bike is a yr200 ec 250 with Marzocchi forks (regular not upside down ). I've found a manual but it is confusing as it gives 3 different amounts 135mm 145 Mm depending on something or other and then in a diagram it shows 190mm from the top of the stanchen.
Thanks
Ade.
Old 06-07-2016, 04:06 PM
cbutler's Avatar
cbutler cbutler is offline
135 mm is kinda "standard" adding oil will make it stiffer (130 mm) taking oil out will make it more plush (140 mm)
Play with it and find what works for you.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 06-07-2016, 04:28 PM
Cool. Thank you. I'll try it out as standard and go from there then.
How much oil will I need to buy to do both forks then? Again the manual doesn't give a volume of oil.
Old 06-07-2016, 06:06 PM
If the manual provides a measurement rather than a volume, they may be indicating the air gap. Larger air gap equates to less oil and vice versa. Unless they specify that this is a measurement of the oil height. Either way, you will need to add oil until you get the correct height of oil or air in the fork.
Old 06-07-2016, 07:09 PM
You measure the air gap with the fork collapsed and spring removed. The actually minimum air gap will depend on the volume of the fork once springs and spacers have been included. Too much oil and you'll hydraulically lock the fork and the seals will cop a flogging.
With a low oil level you may get away with 1L of fluid, but in many cases it'll end up around 600-700ml per leg. Best to have 2L on hand before starting.
Old 06-08-2016, 03:01 AM
Yeah I understand that part I just didn't know what that related to volume wise so I knew how much to buy.
Thanks Jakobi. I will get at least 2 ltr's then. Just to confirm. The stanchion needs to be at its lowest position to measure the air gap of 135mm?
Old 06-08-2016, 06:44 AM
Yes 2 liter and lowest position with the spring out.
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
fork clamp bolts and fork oil level gassergrant Enduro Suspension 2 02-16-2016 04:08 PM
fork help bkwdc Enduro Suspension 12 08-27-2013 01:31 PM
not all 5 wt fork oil is the same! matt_tidball Enduro Suspension 3 04-25-2012 06:21 AM
fork seal change sachs fork Madhead Enduro Suspension 13 01-13-2012 07:49 PM
Fork oil redrider7202 General Discussions & Announcements 2 02-24-2011 10:16 PM
