Old 07-24-2016, 02:50 PM
Anders's Avatar
Anders Anders is offline
Originally Posted by twowheels View Post
Michigan Engineering will make you 7mm ID shims if you commit to a minimum order of 1000 pieces ... of any particular size
Yea, right...
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 08-15-2016, 02:34 PM
dewenduro's Avatar
dewenduro dewenduro is offline
I bought on www.motocrosscenter.com
Original GASGAS items, ref numbers:
12460007486 ARANDELA CIRCULAR 14X7X0.10
12460007497 ARANDELA CIRCULAR 16X7X0.10
12460007508 ARANDELA CIRCULAR 18X7X0.10
12460007518 ARANDELA CIRCULAR 20X7X0.10
12460007528 ARANDELA CIRCULAR 22X7X0.10
These are circle shim.
Maybe 24x7x0.1 is delta shim.
other sizes:
http://www.motocrosscenter.com/shop/...submit_search=
Marzocchi 48 shim stack profile. Barbs Enduro Suspension 17 02-29-2016 07:12 AM
Marzocchi 45 shim advice? motopsycho87 Enduro Suspension 17 10-20-2014 12:47 PM
Countershaft sprocket shim 3hunerd Enduro Engine - 2 stroke 5 03-24-2012 09:29 AM
45mm zoke shim id Ed Ventura Enduro Suspension 1 09-22-2008 05:34 AM
Rebound shim recommendations (stiffer) stay_upright Enduro Suspension 4 09-20-2008 02:20 PM
