Old 08-05-2013, 12:00 PM
SingleTrackMind SingleTrackMind is offline
Post estart headlight turn signal replacement options
Forgive me if this was already covered in an earlier thread. I can't seem to find much so I thought I'd post a new thread.
I'm looking for an after market replacement for my start / kill / headlight switch. I don't need turn signals and would like to find something with a smaller footprint.
I've been looking through the sicass racing options.
http://sicassracing.com/store/switch...c39c33e7b00bd4
I am considering splitting it up between two switches but would prefer just a headlight / kill / start switch. Let me know if anybody else out there has found something.
~Shaun
2011 GasGas 300 Nambotin replica
2007 KTM 450XC
2005 GasGas 300 TXT Pro Trials bike
2006 KTM 85/105sx - Sons bike
Old 08-06-2013, 09:31 AM
Neil E. Neil E. is offline
The switch you linked is a good choice. I installed one on my bike. I don't have signals mounted, so I'm using only the HI/LO and horn button (and LEDs).
To keep all functions on one switch you could wire the turn signal switch as a kill switch (both left and right will stop the engine). You could use the horn button as a start button (momentary for estart). The HI/LO would connect normally.
There is also a row of 3 LED indicators on top of the switch (red/yel/blue). They can be individually connected or not used at all. Some time spent working with a multimeter will allow you to "map out" the circuits inside the switch.
On my setup I wired two Radio Shack momentary push buttons. Black one beside the throttle for estart. Red one beside the clutch for kill. I have a horn on my bike since it is handy for signalling buddies on the trail.
2011 EC250E
Old 08-06-2013, 03:07 PM
Thanks Neil, I'm hoping somebody puts a link up to some super awesome mini switch that does everything. But I think I have decided to go with two switches. I wish there were a way to integrate a couple SMALL switches on the handlebar mount. I saw some interesting controls on the adventure rider site.
Thanks again for taking a few minutes to reply to my post.
~Shaun
2007 KTM 450XC
Old 08-06-2013, 07:23 PM
Here is my bike leaning on a tree; lots of stuff on the bars.
2011 EC250E
Old 08-07-2013, 10:18 AM
Default Controls / mounting
What kind of mount is that for your voyager? You've got quite a bit going on there! Nice and neat. I noticed you moved your "rain button" over to your bars. I can't say I have ever used mind.
~Shaun
2007 KTM 450XC
Old 08-07-2013, 12:51 PM
The Voyager mount is a piece of 1 x 3 x 1/8" aluminum angle cut down to size with a small flange remaining at the front. A clear piece of 1/4" lexan is attached to the flange. It acts like a "windshield" to deflect roost and branches. The plastic does not interfere with the antenna signal. I also machined up two 3/8" wide clamps that go around the 7/8" handlebar. I purchased the Trailtech accessory mounting plate, but only used the grommets from that plate.
My biggest complaint with the Voyager is that it can only display tracks two ways. A standard line or a thick line. If it also had a dotted line and a thick dotted line, it would be much more useful. I use the standard line for my map tracks and the thick line for my current track. A dotted line would allow me to differentiate forest roads from single track.
2011 EC250E
Old 08-07-2013, 05:03 PM
Coop's Avatar
Coop Coop is offline
Excellent switches:
http://www.highwaydirtbikes.com/HDB_Shop/
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Old 08-12-2013, 01:55 PM
Thanks, I like the idea of having a dash. It would be great if they had a contour mount with a dash. Uncluttered bars by relocating a couple switches to the top bar mount is very appealing.
~Shaun
2007 KTM 450XC
Tags
aftermarket switch, headlight, kill, start
Turn Signals Wicitup General Discussions & Announcements 15 10-28-2014 04:12 PM
How can i turn my lights off nickp General Discussions & Announcements 2 10-28-2012 07:56 PM
turn signal and tail light problems 06EC300 Enduro Electrical & Wiring 0 03-20-2011 08:06 PM
Turn signal relay 2006 FSE 450 kesnerp Enduro Engine 4 stroke (including EFI & Exhaust) 0 01-14-2009 04:22 PM
