Clutch question
My new to me 2010 EC300 runs fine except for the clutch. Actually the clutch works fine when engaged, the problem is about half the time when I let out the lever it jerks or lurches. The lever itself is smooth, the clutch basket looks new. Could it be something with the slave cylinder? Where can I get parts, it is an AJP and they went bankrupt. Any help appreciated.
No direct experience on this but maybe the Oring on the slave piston has "rolled". It is losing any fluid from the reservoir over time? Any chance someone has put the wrong fluid in and messed up the seals?
2011 EC250E |
Clutch question
The clutch does not leak anywhere, in fact it is perfect except for the lurch on take off (sometimes). I may investigate the slave cylinder but I don't have experience with it, was hoping I could smooth it out without messing with the slave.
Matto Cycle will ha e the parts for the AJP. They are still in business under a different name. I believe it’s braktech or something like that.
On another note, I had this happen before and it was the master cylinder that was going bad. Instead of fiddling with the inferior AJP stuff, I just bought a Magura hymec 167 master cylinder. It’s a direct replacement. If you go this route you need to get the 9.5mm one. Got mine on Amazon. Sent from my iPhone using Tapatalk |
Clutch problem
Thanks Memphis,
I may buy a new master cylinder if necessary. |
Clutch question
Any other suggestions welcome, I am not in a hurry to buy a new master cylinder.
How are your steel plates? Straight or warped? Warped plates may lead to the clutch engaging abruptly.
I really don't think that it's anything to do with the clutch actuator system (master and slave cylinder). I believe that your issue is with gear box fluid weight. The GG clutches chatter at engagement with the certain fluid weight. I recommend that you try different weights of transmission fluid. I had good results with a 50/50 blend of Type F ATF and 10w30 motor oil. It's cheap enough to change the trans fluid that you can test different blends to find what suits you. Oil weight has a significant affect on clutch engagement, so spend a couple of $ and figure out what works best for you. It is a LOT easier to change gear fluid than swapping seals.
Don't forget to look at straight weight gear oil along with multi weight motor oil. Heavier weight oil will also cause clutch drag (hard to find neutral); once I swapped to the 50/50 blend it was very easy for me to find neutral with the bike running as well as reduced engagement chatter.
Phil (New bike pending...) |
clutch question | Rabbitist | Enduro Engine - 2 stroke | 0 | 02-27-2012 08:23 PM |
FSE 400 clutch Question | Gerko | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 02-01-2011 06:20 AM |
Clutch question. | darren | Enduro Engine - 2 stroke | 5 | 09-23-2010 09:16 AM |
KTM 50 Clutch Question... | tprnottp | All Other Bikes... | 8 | 09-28-2008 11:17 PM |
FSE Clutch Question | mike989 | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 09-24-2007 07:29 AM |
