Old 10-11-2016, 05:01 PM
Willsyj Willsyj is offline
Default 08 FSR 515 hard to start.Flooding.
Hi everyone, I have a 08 fsr 515. Got it with a leaking head gasket so pulled it down got new gaskets, faced the head and new piston and rings. Since then it's been really hard to start if I can get it started at all. Smells like it's flooding. Runs ok when it starts. Fires most of the time and puffs out grey black smoke when trying to start as if it's getting way too much juice. When I was plugging everything back in I crossed over the injector plug and temp sensor plug. Will this have damaged the sensor or ecu which is causing it to flood? What are the readings meant to be for the temp sensor? Any help would be greatly appreciated.
Old 10-12-2016, 01:27 AM
Tafka Tafka is offline
There is a chance that you killed the temp sensor...
Temp sensor reading should be about 3kiloOhms@25C
http://www.boltekdesigns.com/Downloa...e%20sensor.pdf
Old 10-12-2016, 05:01 PM
Thanks. I did see the link you put up. I measured mine yesterday at about 2kohm.
Is that too much out of spec?
Old 10-13-2016, 12:40 AM
It depends what was the temperature when you measured it?
2KOhm would mean temperature about 30-35C.
When i rebuild my FSE450 then it was also hard starting...but after some time it got better.
Did you mess around with TPS sensor? (throttle position sensor)
Old 10-13-2016, 06:12 AM
I'd say it was less than 20degrees. Haven't touched the tps. Should I?
Old 10-13-2016, 06:30 AM
No! If you don't have software and cable to reset the TPS then leave it! Just asked if you touched it
But if you say that temp was more like 20C then i think the water temp sensor is busted. It should be over 3KOhm @20C.
But lucily the sensor is pretty cheap and car sensor will fit! Most car part shops should find a cross-reference part when you give them part nr WTS05 or for example Hella code is 6PT 009 309-291. Or maybe you can borrow the sensor from somewhere for testing
Old 07-13-2020, 04:48 AM
GMaster GMaster is offline
Old topic ,didnt want to create new one , but i had similar problem , in my case it didnt flood ,but starting was very hard ,sometimes it didnt even start. I had big crack inside the rubber hose that ise between engine and throttlebody. After fixing that ,engine starts usaually with second or third attempt(dont know is it normal) but a least it starts now.
After taking cover of the bike i noticed a little sensor near the ecu ,it looks like open temp sensor. Can somebody explane the purpous of that sensor.
GAS GAS 515
Tags
ecu, sensor values, temp sensor
Hard to start TRAILBLAZER808 Enduro Electrical & Wiring 30 08-24-2014 10:36 PM
Hard to start TRAILBLAZER808 General Discussions & Announcements 3 08-14-2014 06:41 PM
What would make my ol' 99 EC300 so hard to start? flatout111 Enduro Engine - 2 stroke 11 08-04-2014 07:41 PM
EC515FSR hard to start when cold Toontje Enduro Engine 4 stroke (including EFI & Exhaust) 12 07-01-2014 03:17 AM
Hard cold start rupecopp Enduro Engine - 2 stroke 8 11-30-2008 10:54 AM
