"Wanted to Buy" & "Want To Trade" Bikes or Parts |
Wanted Ohlins shock for 99 EC300
I've been having trouble with the shock on my 99 EC300 I think I would like to start fresh and rebuild a different unit. I would also be interested in buying all the associated rear linkages.
Willing to pay cash or I have the front end off the same 99 I could trade. Forks triples and wheel. Email is quickest Danny boardrider247 at gmail dot com |
Are you sure your shock can not be rebuilt. I would send it to Les at LTR Racing as he has the ability to repair and or replace any bad components.
If you are set on getting another one, I think that you can use a shock from 1998 to 2000. At some point I thought they changed the shock length and the lowered the upper mounting point. Maybe someone else can confirm or you can do some research. |
All healed up, and ready to burn some fat. |
If I had measurements...I could check against a shock from the related KX family...'cause Ya never know. I never measured the shock from my 00(it lives in Oregon now), but is definitely longer than the shock on my 03. I was gonna swap the beefier KYB forks I have, onto the 00(replacing the wp43s). While I was I was at it, I was going to check fitment of the shock(as they are a serviced matching set). Hence the reason for the earlier suggestion.
Right now the seal head has been replaced on this shock twice and gone through by a pro.
The problem is it keeps leaking which is leading me to believe the the shaft may be ever so slightly bent causing this problem. I'm going to rebuild the linkage to see if that cures the issue but wanted to get feelers out there for a shock now. I'll pull my shock out today and take some measurements. Thanks for the suggestions guys. |
Is it true that the shorter newer shocks (03 & newer) have an internal spacer to shorten them up but can be removed to make them the length of the older 02' and older shocks??
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 Last edited by nknudsen; 09-02-2014 at 09:27 AM. |
I have an 888 Ohlins shock from my 2005 250.
I should have the shock from my parted out 99 200 gasser. I'll look. I do have the linkage.
Thanks!! Danny boardrider247 at gmail dot com |
Must have sold the shock, I can't find it. If your linkage knuckle is bad I do have that. Will need new bearings, sleeves, and o-rings.
2012 Ohlins lower shock bushing and Problem with shock. | CDBiker220 | Enduro Suspension | 1 | 08-04-2014 09:35 PM |
04 ec300 shock mount clevis wanted!! | jt633 | "Wanted to Buy" & "Want To Trade" | 2 | 05-27-2013 04:54 PM |
2001 EC300 Ohlins Shock Help: Service and Setup | krazy | Enduro Suspension | 7 | 11-24-2012 05:07 PM |
Wanted ohlins shock for 07 ec250 | gasgasandrew | Enduro Suspension | 0 | 08-27-2010 03:35 AM |
