Old 03-17-2018, 12:39 PM
rvangeel rvangeel is offline
Default PFP adjuster on 48mm Marzocchi’s
Has anybody had the PFP adjuster seize up on the 48mm CC forks? I have the cartridges removed from the fork , the adjuster seems seized. The other problem is the cartridge spring has a couple millimetres of free play. The adjuster seems like it is fully retracted. I wanted to just snug up the adjuster so the spring doesn’t have any free play.
Old 03-17-2018, 10:05 PM
The free play in the spring isn't a problem. It's taken up on assembly..
You can disassemble the whole setup; a few threads on it if you search.
Then lubricate the threads with a thin silicone based grease and they'll run nicely. Be VERY VERY VERY VERY careful when threading the upper cap parts back together... it's a super fine thread.
Old 03-18-2018, 03:26 AM
And to add to Jake?s advice some ?mechanics? use the pfp to undo the cartridge as they don?t have the proper tools... I?ve had forks back from tuners like this as well...
48mm Marzocchi PFP fork oil Anders Enduro Suspension 7 11-04-2015 12:07 AM
Marzocchi 48mm Challenge! Jakobi Enduro Suspension 21 08-02-2014 04:10 PM
48mm Marzocchi Manual Clay Enduro Suspension 5 04-11-2013 01:51 AM
new 48mm Marzocchi forks?? Dave A Enduro Suspension 19 11-04-2011 07:48 PM
