Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 03-16-2021, 11:25 AM
Posie67 Posie67 is offline
Default EC200 fork cap
Looking for a new (or used) fork cap for 2000 EC200 with the WP43 forks. Previous owner stripped the hex on top and I've upped the ante by breaking the rebound adjuster knob. It's off now but pretty beat up and I can't locate a replacement. Thanks in advance!
File Type: jpg 8E77388F-CE72-46E9-BDA4-0DB022D4EEE7.jpg (114.9 KB, 13 views)
Old 03-16-2021, 02:33 PM
thats what happens when you forget to loosen the top triple clamp bolts - fork cap is usually just snugger than finger tight.
If you know a freindly machinist they can probably make up a new rebound adjuster - it was a common issue with the sachs forks
Old 03-16-2021, 03:13 PM
Yeah, I loosened the top clamp. Even tapped a screwdriver in to spread the clamp to be sure there wasn't any pressure on the tube but the Hulk must have the last guy to work on it. Only way I got it out was with a round punch inside the bleeder hole.
fork clamp bolts and fork oil level gassergrant Enduro Suspension 2 02-16-2016 04:08 PM
Fork and Shock Seals for 2001 EC200 mattholew Enduro Suspension 11 01-08-2016 08:14 AM
Need to know on an '09 EC200? liv2day General Discussions & Announcements 2 03-11-2014 04:02 PM
fork seal change sachs fork Madhead Enduro Suspension 13 01-13-2012 07:49 PM
