Old 04-06-2017, 07:09 PM
Halcon Halcon is offline
Default Jetting help please!
Hi All, I am the proud new owner of a 2013 XC300, but am having trouble getting it to run properly. It didn't run too well on my short test ride before purchase, but bike seemed solid. I took it for a longer ride and it ran strong on the pipe at wider throttle positions, but burbled down low, I also heard some detonation on a light throttle. I pulled the jets to check everything, original 42 pilot was partially blocked, I swapped in a new 40, main was ok. I put in a new BR8EG, new air filter, new 94 octane 50:1. I am at 3000', temp was 15c (60f) it now runs worse. I have a N1EF on 4, 40 pilot and a 168 main. Any suggestions on which way I should go would be gratefully accepted, thanks.
Old 04-07-2017, 11:02 AM
Neil E. Neil E. is offline
Review the jetting threads. N1EF is a very poor needle. Almost anything else will be much better.
Old 04-07-2017, 08:10 PM
N3CH, N3CJ, NEDW are all good needles. Pitch the N1EF in the garbage. Also really surprised you were hearing detonation out of this motor. That is just something they don't do. Sure you weren't hearing the power valve rattle? They are pretty notorious for that.
Old 04-08-2017, 04:31 AM
pigpen966 pigpen966 is online now
As others have said, ditch that needle. I have a 13 300 also and am running a N3CJ (yz250) 2nd clip, 42 pilot and 178 main. This is perfection
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 04-09-2017, 12:47 PM
Thanks guys, I am not very familiar with this motor, it could be power valve rattle, I have been a long time 4 stroke guy so not a noise I'm used to hearing. I have ordered a NEDW, as no one around here had a N3CJ. Hope that sorts it out. Thanks again for the replies.
Old 04-20-2017, 01:59 PM
Update_ Got a NEDW needle and that has really helped things out. I am now running the NEDW needle on the second clip, 168 main and 40 pilot, air screw at 2.5 turns out. I suspect that I am still a bit rich on the pilot as it starts from cold without the choke. Think I may try a 38 pilot to clean up the last little burble. I'm at 3500' and temp was about 12 C during testing. My riding area is higher and its finally getting warmer in the frozen North so a bit leaner should help. If anyone has any suggestions I'm happy to hear them, thanks,
Old 04-20-2017, 03:22 PM
webmaster's Avatar
Administrator
Did you back off the idle and reset your air screw when you swapped to the new needle? if you didn't reset these after swapping needles it will be "off" - you will still be "pulling over"... Where is your idle screw at now - is it still nearly "coil bound" (all the way in)?
It might also help to know which slide your bike has...
Old 04-20-2017, 09:42 PM
Thanks Jeff, I have a 38 mm AS II carb with a 7 slide. I did adjust the idle screw, had to back it out 2 or so turns, my air screw was at 1 1/2, now 2 1/2.
A Few Jetting Basics (ie Jetting 101) n_green Enduro Intake/Carburetion - 2 stroke 8 05-23-2014 05:42 PM
300 jetting adv rider Enduro Intake/Carburetion - 2 stroke 9 01-27-2014 11:52 PM
How do you know you got your jetting right ? Krisden Enduro Intake/Carburetion - 2 stroke 21 07-01-2012 03:49 PM
