Old 10-29-2015, 11:50 AM
12Bravo's Avatar
12Bravo 12Bravo is offline
Default Forks
I just talked to a local shop that is going to set my suspension up for my weight.
He was talking about the fork seals and how expensive they are and how he will only put OEM seals on the forks. Why is that?
Is Hall's the best place to get those seals?
How can I tell what forks I have? I have looked online and seem to get any solid information about them. I don't see any numbers of writing on them they are plain gray at the bottom and shinny up top.
What started all this is the front end washed out several times while riding the other day and the rear end hit me like a bucking bronco several times, I about ate a tree!
EDIT: Frame says 98 250 motor is 99EC200......I looked for a picture and history of the bikes and can't find one for the EC but plenty of trials history.
"There is no room in life for Regret, it's a useless feeling that leads to a negative attitude" I would rather call it the "Stupid Tax"!
Old 10-29-2015, 11:57 AM
nknudsen's Avatar
nknudsen nknudsen is offline
Measure the shiny part of the fork, it should be 45mm. If so, they are Marzocchi Magnum 45 forks. There should be some good aftermarket seals available or try Halls.
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 10-29-2015, 12:08 PM
cbutler's Avatar
cbutler cbutler is online now
Have you set your sag ?
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 10-29-2015, 12:23 PM
12Bravo's Avatar
It's way off, I would have to pre-load the rear to much. I did try and set it.
Old 10-29-2015, 02:05 PM
I would get SKF seals if they are available
Old 10-29-2015, 04:05 PM
shang shang is offline
+1. The SKF's are as good as it gets.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 10-29-2015, 07:48 PM
+2. You have to shell out more coin for them, but they last much longer than OEM, in my experience. They say less stiction as well, but I cant tell much of a difference.
Old 10-29-2015, 08:16 PM
cbutler's Avatar
Without the sag set you can just expect the front to wash get the proper springs and go from there.
SKF seals are top of the line.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 10-29-2015, 08:43 PM
12Bravo's Avatar
So should I fork over the $600 for a full front and back suspension job with him having me there to set sag and all.
Or....Get the right rear spring and see what happens?
P.S. The $600 includes; Springs Front and back and re-valve. Plus a one on one with setting sag right.
Old 10-29-2015, 11:18 PM
CACTUSREID CACTUSREID is offline
front and rear springs, revalve and help with setting it up-for $600?? Jump on that offer while it's still an option. i'm not sure about prices where you are , but up here in canada eh, 250-300 bucks will buy you a set of springs, and then the valving,seals,oil, etc is all on top of that.
what forks to use gassergrant Enduro Suspension 66 02-10-2020 12:35 PM
What forks do I have? jprizz Enduro Suspension 7 06-25-2014 03:46 PM
Which used forks do I have? wmcpb04 Enduro Suspension 17 06-11-2013 07:59 PM
43 mm wp forks. jhendr3702 Enduro Suspension 4 10-18-2010 06:46 PM
forks sen480 General Discussions & Announcements 1 03-25-2010 04:54 AM
