handlebar raisers
Want to raise my bars by 25mm i can get spacers made to fitt under bar clamps but looks like odd shaped bolt holding clamp to top yoke, what other option do i have, loke the bend of the bars i got so dont want to change them just get them higher
on my standard bar I used the universal bar lifters that bolt in to the original clamps
http://shop.1stmx.co.uk/universal-ba...ars-4993-p.asp picture paints a thousand words they work well and feel safe
03 ec300 honda cr500 94 |
Take the caps off your bar clamps, pull your handlebars up and reinstall the caps upside down underneath the handlebars then add new caps on top with longer bolts.
looked at doing that but a cheaper option was for a mate to turn up some alloy spacers and i re-shaped the head of two stainless bolts to fit the gasser clamps, total cost ?1.50 for the bolts.
Exactly what I did , got some bar, drilled a hole in it, got longer bolts and ground 2 sides off them
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
I don't know a lot about metal hardnesses but it might be worth looking at how hard stainless is compared to say a grade 8 bolt. I thought stainless was kinda soft?
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
stainless steel would be a lot harder
Bolt grade research will show that stainless is not as hard as you think.
An 8.8 bolt would be way stronger. Gas gas bolts on the bars and triples are 12.9 which is a very, very strong bolt and at least twice as strong as stainless, probably three times.
There are diffrent grades of stainles like s130 very tough used in the aerospace industry.
harder means more brittle, the bolt grades are to do with strain when tightening, |
so is a stainless steel bolt strength measured differently? (just curious)
Gas Gas handlebar pad | Jgracey | "Wanted to Buy" & "Want To Trade" | 1 | 10-29-2014 10:24 PM |
EC200 06 bar raisers | ypm25 | Enduro Chassis & Body | 1 | 09-05-2014 04:45 AM |
Handlebar bends | gasser | Enduro Chassis & Body | 0 | 07-09-2013 07:06 PM |
Which handlebar is this. | skraMnoR | Enduro Chassis & Body | 15 | 04-11-2012 09:06 PM |
