Old 12-06-2009, 07:18 PM
moto9's Avatar
moto9 moto9 is offline
Default I love my Gas Gas but?
So, I've had my 08 300 about 8 months now and had time to get to know the bike pretty well.
I love riding it and in this area I have almost nothing to complain about!
I ride some fairly nasty stuff so the bike gets a good workout on every ride.
I love the power, I did add a FWW which aided in traction thru the greasy roots that litter our local trails.
Did some minor changes to clean up the overly rich jetting .
Handling is awesome, light, nimble, tracks well and the ergos fit my 5' 9'' frame well.
Suspension was a little harsh front and rear, but I was able to sort that out with a re-valve, I like that the marz forks and sachs shock were easy to work on.
So far the bike proved to be very reliable, in the 8 months I had to very little to do but clean the air filter and change the trans oil.
So, what's there to complain about...mostly Fit and finish !
"Are you listening Gas Gas?"
Here's my don't likes:
1. notchy shifting:
It's not bad, just not as smooth as I'm used to (Honda/Yamaha)
2. squaky clutch:
That dose bug, it's not constant, mostly under a heavy load 2nd 3rd gear.
3. Brittle plastics:
They crack easily and don't hold up to impacts well
2. Gas tank shroud mounts:
Get rid of the cheap wood style screws that screw directly into the gas tank plastic, this is very Ala-Chinese cheapo style ...follow the top 5 manufactures mounting design.
3. Using nuts on the back side of so many mounting bolts:
What a complete "pain in the ass" to work on sometimes...take the sub-frame mounts...getting at the nuts of the upper mounts with a wrench is a hassle.
Would it be so hard to add a nut welded to the back side of the frame on some of these mount points??
I mean GG builds a bike that is so close to anything else on the market...but in my opinion...then drops the ball on areas that are very crucial to the consumer and probably not that much more in cost to add to the manufacturing process.
In any case I'd pay more for a bike that had better fit and finish.
4. head bolt sizes:
Ok, would it be so hard to use common sizes, 8mm, 10, 12, 14, 17, 19,
the bolts on my bike are a guess, I'm constantly running back and forth for wrenches...13mm, 15, 16, 18 etc... what the bloody hell.
5. Lower chain guide:
The lower tension-er style guide is too prone to damage, I think it's a weak point and don't see the advantage over a the style every other manufacture uses.
Conclusion:
So, in reality this is a very short list and not that big of a fix for the manufacture but is the difference between GG and a top Japanese bike.
Fit and finish is something that is very crucial to a owner and prospective buyer.
First thing I noticed when considering a GG was the cheap wood screw shroud mounts, as well as backing nut plates on just about every bolt.
So, I'm thinking what other shortcuts were taken?
Fortunately, everything else seems solid.
I wrote this because IMHO GG is so close but yet so far!
I say to GG take that last step ...add the missing fit and finish and climb to the top!
Old 12-06-2009, 10:10 PM
noobi's Avatar
noobi noobi is offline
my 09 ktm 250exc uses screws to hold the shrouds onto the tank.
Old 12-06-2009, 10:34 PM
gasgasnz gasgasnz is offline
gas tank shroud mounting is surposed to have changed for 2010 models?
Old 12-06-2009, 11:23 PM
coolum74 coolum74 is offline
Buy a 4 Banger Honda so you can revalve it in 1000klm.
Adam
2006 FSE450...Gone
2011 EC300e
Sunshine Coast, Queensland
Australia
Old 12-07-2009, 05:32 AM
moto9's Avatar
Been there done that,between 2004 and 07 I raced three 450's and one 250, actually only the 250 needed a valve job with 150 hours...if that's what your refering to.
Besides, I think your missing my point.
Just because Honda had some valve issues on their early F's does not negate what I stated in the thread...everything I said was valid.
I'm just saying GG could refine what is already a great bike...with just a little more design effort on their part and give it that fit and finish it's missing in some areas.
Old 12-07-2009, 05:46 AM
Nick's Avatar
Nick Nick is offline
Have you had a problem with the chain guide ? or just dont like how it looks ? I've yet to have a problem with one.
Old 12-07-2009, 05:51 AM
F_G F_G is offline
I'm with ya' on the hardware thing. Holy crap, how many wrenches should you have to use? The mismatched hardware is almost embarrassing.
Other than that, pretty dang happy. Actually like the use of Nylocs to back up bolts, mush easier to change than a gnarled up captured fastener.
Try different tranmission oils, found one that improved shifting and quieted the clutch down.
Chain guide - non issue. I changed every stock one on every other bike I owned as they are all crap.
Frank Staley
President in Exile-Arizona Trail Riders
"You live more in 5 minutes on a motorcycle than some people do in a lifetime" - B. Munro
Old 12-07-2009, 05:15 PM
no issues with my chain guide either ..
agree with you on the multiple choice wrench/fastener set up!!
toss in the allen head bolts and you got a real smorgashborg of fasteners to deal with. most everything should be 8,10, or 12mm!!!
Old 12-07-2009, 05:32 PM
REVERUP's Avatar
REVERUP REVERUP is offline
Yes I agree, the multiple hardware sizing is getting a little long in the teeth. Even if Gas Gas got rid of 1 or 2 sizes it would help. I do however think I like the nut on the back over a welded on or tapped part as its far easier to replace the nut if it strips out.
I'll take a squeaky clutch over one that wears out in a few hard events any day. The Gas Gas stocker is the most durable clutch I know of, and IMHO doesn't really seem to me to be any noisier than others unless really heated up in a survival style race, and at that point who cares, my mind and body are screaming too.
I think the stock plastics are pretty darn good. In all the years riding, racing Gas Gas Ive only had two replace two pieces due to breakage. Maybe I've been lucky.
I agree on the wood screws on the Gas tank there is a better way.
The stock chain guide works for some. I have bent one and ever since, that is one of the first things I change out.
I also wouldn't be disappointed if they decided to make the oil fill hole a bit larger, and went away from the black powder coat fad right now. Ya the moto style black rims, swing arm, forks etc...
Roscoe
Old 12-07-2009, 08:53 PM
roostafish's Avatar
I'm with ya on the fasteners too, and the itty bitty oil fill hole. What's up with that anyway? Minor annoyances if you ask me, compared to the performance of the bike as a whole.
I have broken one chain guide, but as a whole I think it works fine. It has worked fine for Husqvarna for 30 years or more, and I've never heard a complaint from the Husky crowd.
Mike Sheetz
OMRA #21AA
'15 KTM 300 XC-W
Gran Prix Cycle
LTR Suspension
RB-Designs
Why I love my GasGas Lex P GasGas Member Polls 61 12-06-2010 07:24 PM
Gotta Love It Rick Pictures & Videos 1 05-04-2010 05:59 AM
I love my Gasser - again.. stay_upright General Discussions & Announcements 7 07-16-2008 01:40 AM
I'm in love SpeedyManiac General Discussions & Announcements 0 03-26-2008 12:23 AM
I think I'm in love SpeedyManiac General Discussions & Announcements 3 06-17-2007 11:47 PM
